Vortec To 700 Bellhousing Question
Discussion in 'The Garage' started by FoolSizeK5, Jan 9, 2006.
  1. FoolSizeK5
    FoolSizeK5 Registered Member
    Jan 4, 2006
    37
    Grovetown Ga
    Am i just going crazy or are my old factory 350 bell housing bolts to long for a vortec block to bolt to a 700 bell housing ??????
  2. Hermy13
    Hermy13 Registered Member
    Aug 27, 2005
    22
    Iowa
    the blocks didnt change far as i know the tranny holes might just be shorter
  3. FoolSizeK5
    Jan 4, 2006
    37
    Grovetown Ga
    any idea on why the old 350 bolts won't thread all the way in then ?? same block it's the old bolts with the old transmission ? i'm confused if it was the vortec bolts that would make sense
  4. K5dreamer
    K5dreamer 1/2 ton status
    Mar 14, 2005
    3,084
    Alexandria, Va
    only difference between the blocks to my knowledge was the swap to a one peice rear seal, the trans bellhousing bolt holes should be the same. Did the block sit out anywhere for an extended period of time? check the holes for debris and run a tap through them but dont force them too far in, im not sure if youd hit a water jacket or anything. But it sounds to me like there is just something in the holes blockin them up. To be sure though, call up your local chevy parts dealer and ask if the pn for the bolts are the same for the two different engine applications. if they are different, they may have changed the length or thread count or something along those lines.
  5. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    I was running a vortec shortblock in my truck, the bellhousing bolt holes are the same, only diff I found was that the bypass hole for the old reverse rotation waterpump(non vortec) was not drilled all the way, since the vortec waterpump doesn't use that hole for bypass(uses a hose on top to the intake)
