Vortec?
Discussion in 'The Garage' started by Confedneck, Jan 14, 2004.
  1. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Ok.. the votech i go to for night school (that the ford dealer i work for, pays for) has an 89-91 chevrolet 2wd with a 350.. is it a vortec?? or at least vortec heads? i told him id buy the motor, trans, rear end and rear springs when he goes to part it out/scrap it.. and he said hed think about it.. but i dont want the motor unless its worth having..
  2. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    As far as I know Vortec heads were first installed in 96
  3. Confedneck
    Nov 1, 2002
    5,236
    my 86 was optioned with a 4.3 vortec v6.. so thats why i was curious..
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Vortec 350 didn't appear in trucks until '96. If it is in fact a 350, it's the same 350 TBI that was used from '87-'95.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Not a vortec. But if it is a half ton, it may have the early swirl port heads. They are similar to vortecs but with larger 76cc combustion chambers. They are better heads than the earlier FI heads but the intake manifold still sucks.
    If you get it cheap enough any chevy parts are worth having. all you need is Vortec heads and manifold and yur good to go. a roller cam would be nice also the block is already tapped for the guide bosses.
  6. Confedneck
    Nov 1, 2002
    5,236
    right now im trying to find some vortec heads to put on my truck, a manifold to bolt to them and put my q-jet on.. so i can get my exhaust done too.. id love to pull some power out of this motor before i build the 4 bolt block in the garage...
  7. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Thye didnt use the vortec V6 until 93 0r 94. Your 86 would just have a 4 barrel on it. I know my 92 is just a 4.3 tbi.
  8. dyeager535
    26,977
    No, GM was calling the 4.3's Vortecs WAY before 1993. I've seen '88 Astro's wtih "Vortec" valve covers on them. Still can't confirm what exactly that meant, if anything other than a marketing ploy, but I have seen pre-1996 Chevy information that mentions "fast burn heads", which are apparently the same crappy TBI heads with better combustion chamber shapes.
  9. Confedneck
    Nov 1, 2002
    5,236
    yeah.. i think earlier "vortecs" were just heads.. im not sure though, and thats why i asked..
