VSS/DRAC Question
Discussion in 'The Garage' started by rpellicer, Jan 18, 2005.
  1. rpellicer
    rpellicer Registered Member
    Dec 20, 2004
    38
    Susanville, CA
    Hi,
    I'm considering making mods to the DRAC as some of the posts in the forums suggested. My problem is, there seems to be some conflicting info as to whether my vehicle uses a 2 or 40 pulse VSS. It's a 91 Blazer w/ 350TBI/4L60/NP241. Does anyone know for sure, or is there anything I can check to be certain? Thanks.
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Alright, I am not 100% sure here... But, If I had to guess, I'd say that the truck came with a 4 pulse VSS, then used a DRAC to convert to whatever signal the different systems needed, starting when they switched to an electronic speedometer.
    http://www.chevythunder.com/fuel%20injection%20elect.%20pg%20B.htm
    There is some VSS info on this page, just scroll down a bit. Shows pictures of the different types of VSS, so you can visually confirm it.
  3. dyeager535
    26,980
  4. rpellicer
    Dec 20, 2004
    38
    Susanville, CA
    Thanks for the clarification. What threw me off was an article published by JTRthat stated that all TBIs through '91 used the 2 pulse.
