VSS on TBI... where is it?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BillyBob, Jan 19, 2002.
  1. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I've been looking at the gutted dash of my 87, but I don't see where the VSS is. The cluster looks like a normal cluster... is it in there? I just wanna make sure that, if the TBI has one, I have it.
    <a target="_blank" href=http://billybob87k5.50megs.com>Homepage of Porky & Stinky</a>
    ".. Sanatarium.. leave me be..."
  2. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Check the back side of the cluster for a yellow box. (vss).
    Jim
    88 Silverado K5 5.7-700R-208-10 bolts-4.56-35in
    Procomp AT's- some ORD stuff & a CV driveshaft
  3. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I think my sensor is green but I know the VSS wire is the brown.
    DRIVE IT LIKE ITS YOUR BOSSES!!!
    Luke
    84 K5
  4. BillyBob
    Feb 23, 2000
    557
    Dumont, NJ
    Well, nothing it on the cluster/ speedo cable that's a box.. did 87 even have VSS in the cluster? this is very confusing
  5. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    The sensor itself is on the tail shaft of the transfer case, at least for 90-91. I thought '87 was still using a cable for speed indication...?
    Haze gray and underway...<font color=blue>or blue, in my case.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/album/26246038MbQsYWKcbo>U.S.S. Nimitz II</a>
  6. JIM88K5
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I think 89 &amp; up have the sensor in the transfer case. Prior to that the vss picks up the signal from the speedo head. The last vss I saw was a small yellow plastic box type deal(technical term) up behind the cluster.
    Jim
  7. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Follow the small ribbon-type 3 conductor wire from the back of the speedo head (screws on w/1 screw right next to where the cable goes in). Its maybe 10" long, and leads to a small box (~3/8" x 1 1/2" x 3"), mine's a light green.
    These type started in '82 or '83 on some trucks (ie if you have cruise or an ECU), and ran through '89. '90 and '91 have the sendor in the t-case.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  8. BillyBob
    Feb 23, 2000
    557
    Dumont, NJ
    Well, my 84 has cruise &amp; an ECU for ESC on it.. soo, I don't need to get this sensor off the 87, or do I?
