vss pin
Discussion in 'The Garage' started by nerraw117, Aug 22, 2005.
  1. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    hey does anyone know the pin on the ecm that is the vss input? or drac w/e. is it pin A10? and snyone know how i can tell which pin is which? like a diagram its for a 90 blazer tbi. o and btw my ecm number is 1227747
  2. dyeager535
    26,979
    It's here
    Look closely at the connector where the wires go into it, you will see the tiny cast-in numbers on the connector body (or the locks for the wires), plus if it's a typical two connector ECM, it will be divided in "A", "B", "C", and "D" sections, each row of pins is one of those 4. That designation is also cast into the connector body or locks.
    So "A10" is going to be the 10th wire on the "A" side of the A/B connector.
