VSS question for a 91 NP241C
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Boscolingus, Mar 12, 2002.
  1. Boscolingus
    Boscolingus 1/2 ton status
    Nov 26, 2001
    210
    Santa Clarita, CA
    As I recall on my previous transfer case it did not have a mechanical cable output for the speedo, however this transfer case I just purchased has a mech. output where my truck does not have such a cable.
    The question is - Is there a proper part VSS I need to put in it's place or do I just have my head firmly up my ass on this one =-)
  2. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    not sure this helps, but my 91 sub with 241 has the elec speedo on it. It's not your memory!
    NFI on how to convert a mech one to elec however...
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    One place to check with is http://www.jagsthatrun.com - they have VSS units for just about every application. Not sure if you have an electronic speedo but check that out before you call them.
  4. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    If your's has a mechanical speedo, then it's not a 91 case. My 89 is mechanical, they switched to elec in 90. HTH.
  5. Boscolingus
    Nov 26, 2001
    210
    Santa Clarita, CA
    ahh, ok - just the answer I was looking for, so what all would be the total parts I would need to make it compliant and work on a 91 platform?
  6. Kyle89K5
    2,273
    OKLAHOMA
    Now THAT is a good question. The easiest way that I can think of, since I've never seen a good teardown of them both, is to hunt a 91 case. It doesn't even have to be in good shape anymore, but see if you can find one and compare. It might be as simple as a tailshaft swap, but I'm not for dang sure. I'll look into it a little more and see what I can find.
  7. Boscolingus
    Nov 26, 2001
    210
    Santa Clarita, CA
    so what were getting at is that there was a significant change in the cases between 89/90 and 91? If so it may not be as easy as a part replacement. Could I possibly get someone to take some pics of the VSS unit from all years ranging from 89-91 to see what kind of mess I'm in and how I can go about this, this just might be a learning process in which I'll do the homework for the next guy who gets into this situation =-)
  8. Kyle89K5
    2,273
    OKLAHOMA
    Here's a pic of one with a SYE kit on it. You can see where the elec speedo plugs in. This is on a 90. DP90K5's to be exaact. You can compare a little right there.
    http://coloradok5.com/gallery/albuo71/aac
  9. Boscolingus
    Nov 26, 2001
    210
    Santa Clarita, CA
    well - son of a bitch, it looks as if the entire tail housing is completely different, now Im gonna check out AllData and get some info and part numbers for this situation
  10. Kyle89K5
    2,273
    OKLAHOMA
    That may be good news, head to a parts yard and start scrounging. The 89 is a little more rare than the 90-> because the 89 was the only year for the mech. Good luck.
  11. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    The tailshaft housing IS different on a case with a SYE kit...
  12. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    All you need is a tach and friend to chart out the RPM to Speed ratio(If /forums/images/icons/confused.gif then get another 241C with the hall effect sensor on the tail shaft).
  13. Boscolingus
    Nov 26, 2001
    210
    Santa Clarita, CA
    haha- I took the later route, the 90-91 t-case came in 2 days ago and was in the truck 1.5 hours later, just couldnt wait to get the drive train done.
    Another thing I have noticed is that the pinion angle w/ the 14 bolt looks rather ominous - Im going to guess that it seems to be at 15+ degrees, not sure on what the max degree is before vibration and u-joint exploion, however I beleive I will machine up some 5 degree angled shims to decrease the angle.
    I am curious why this angle issue has never occured out of the thousands of 14 bolt swaps to factory drivetrains ( mine is a 91 w/ 700R4-241C setup )
    More to follow..............
  14. Boscolingus
    Nov 26, 2001
    210
    Santa Clarita, CA
    However I do want to add that I do appreciate the input - I posted this several months ago I beleive and yet you came through w/ a possible fix, now thats just damn cool /forums/images/icons/smile.gif
  15. BigBurban350
    Jun 9, 2002
    711
    Michigan
    Precision u-joints call for 1 to 3 degrees, So youd better shim it. The degree out must equal the degree in to get max life out of drivetrain components due to the acceleration/deceleration vibration due to a u-joint.
    Fun fact /forums/images/icons/smile.gif : a <font color="red"> </font color> CV <font color="black"> </font color> joint is the solution to those damaging vibrations, <font color="red"> </font color> C <font color="black"> </font color> onstant <font color="red"> </font color> V <font color="black"> </font color> elocity
