vss questions
Discussion in 'The Garage' started by nstarry, Apr 28, 2007.
  1. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    I am having problems figureing this out !! so any help will be very nice ..
    I have a 93 two door sport with the 350 TBI, 4l60e, np 241, and the tranny is done! so it is time to upgrade , I am going to do the straight axel next winter ( already bought the gm 60, and a set of 52''ers ) but now the big problems come in. my recent purchase of a t-400 & 205 t-case makes the vss a problem ( computer may get a little mad without proper mods ) can I swap speedos and splice old wires to the new speedo ( vss ) to get this to work ?? is there somthing else going on here ?? please help!! pleeeeaaaasssseeee!!
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
  3. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    I called them and they said that they could not help me :crazy: my set up is a 28000 and all they have is 4000 and 2000 :crazy::mad::crazy: anyone else have any other ideas ??? I know sombody has done this before :confused:
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
  5. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Go to a dealership, order the relucter ring off a 91 4wd crew cab (only year for it) and take the VSS sensor off your case. Drill and tap the tail housing, I believe the vent is on top, already have a hole there anyways to drill out.
  6. jwglover
    jwglover Registered Member
    Jun 2, 2003
    88
    That would be the best,, go to the dealer and buy the ring,
    No one could help me when I did mine,every said to go buy this $300 piece or this $400 piece , no gaurantee that it would work though, so I took the reluctor ring off the 241 and used it, it is the same splines but has to be machine 'skinner ' or thinner to fit in place of the old speed gear,or use a grinder like I did, and then went to Oriellys and bought a nut that would fit on the censor ( 70 cents ) . ground the housing flat and drilled a hole, put the censor through , tapping the housing may work, but the housing is very thin. I have done two others and they all work great.
    So I spent 70 cents and about 1 1/2 ,, along way from $300
    Good luck !
  7. ccj8008
    ccj8008 1/2 ton status
    Apr 2, 2001
    228
    Polson MT
    241
    Consider keeping the NP241. Better low range. That will get you going. If it fails, then consider replacing it. I run a 241 behind a t-400 and a big block and have been happy so far.
  8. dyeager535
    26,979
    I'd agree. 241 seems to hold up very well, and the hassle of trying to retrofit the VSS to a 205 (reluctor ring isn't available from GM anymore) just doesn't seem worth it.
