Wacked out temp guage spins??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GM Man, Feb 18, 2003.
  1. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    When I fire up my truck, the temp guage seems to be working but then it will start to spin really fast. Im guessing this would be a ground problem, but I have never seen this before, so I thought I would ask what might cause this?
    Thanks.
  2. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Right around #3 cylinder is the sender for the gauge. Go and make sure it's not crispy-crittered on a header/manifold. You might want to trace the wire all the way to the back of the block. It follows the spark plug wires to the back of the block.
    I had the same problem but it only did it when it was hot and I hit a large bump. It didn't do it when cold.
