Wahoo-winch problem solved
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, Jan 13, 2003.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I bought a used 8274 winch for $200, the only problem was that the motor would pull but would not release the cable automatically. I had Warn sent me a wiring diagram and after fixing the wiring which was messed up it would still not work. Turns out that one of the 4 solenoids was not working, a new solenoid pack from Warn is $160 but my friend told me that the solenoid looked just like a "Ford" solenoid so I bought one for $8 and it is now working like champ(Finally I found a use for something from Ford). I can't believe I got an 8274 for $200 and an $8 solenoid. /forums/images/graemlins/thumb.gif
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    That sounds like a real good deal. /forums/images/graemlins/grin.gif
  4. swampthang1
    swampthang1 Registered Member
    Nov 18, 2002
    60
    Lufkin, Texas
    Dont depend on the Ford soleniod the reason behind this is because the Ford soleniod is not a constant duty 12 volt soleniod it is designed to run for a few seconds and stop. I have the same winch and ran into the same problem although there is a place here in town that sell warn replacement parts and had the entire soleniod pack complete for $50 what a deal. Anyways dont go out depending on it to have a long live you might want to buy a few extra Ford soleniods for $8 each to have a spare if it goes south while out on the trail
  5. bajaviking
    Apr 10, 2002
    752
    Baja
    "(Ford soleniod is not a constant
    duty 12 volt soleniod it is designed to run for a few seconds and stop)"
    Hmm, I see, just like the rest of the car. /forums/images/graemlins/grin.gif
    Anyway, thanks for the tip. At that price it won't hurt carry a spare.
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Problem isnt the spare part. You could carry 20 spares, but if the load exceeds its capability, I think it will just keep blowing. /forums/images/graemlins/frown.gif
    Acutally, you did say it was only release that was blown.. carry the old one just in case? /forums/images/graemlins/smile.gif
  7. bajaviking
    Apr 10, 2002
    752
    Baja
    Yeah, it's only release, in the worst case I can pull out the cable manually. I guess only time will tell how long the solenoid lasts.
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes, the solenoids that warn uses in the solenoid packs are the same exact thing that ford uses in their starting system.
