Wall Thickness of common axles?
Discussion in 'The Garage' started by sled_dog, Jun 28, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Looking to find out what the average wall thickness of average axles are. Namely, 14 bolt, dana 60, dana 44, whatever else you know. Reason I ask is next time I do a project I'd like to remove the tubes and start fresh. Why? strength. I would truss and retube with thicker tubing. Next thing I build I want to be light and I plan to catch air. Maybe not 20 foot dune jumps but air for sure, and I don't want to worry about it everytime a tire leaves the ground.
  2. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    anyone? I've cut a 14 bolt up, but didn't measure.
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I'd like to know this too, anyone know?
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I know the 14FF has 3.25" tubes and a .5" wall
  5. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I know with the front 60 its got a .5" thick wall
  6. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    I've NEVER seen a 14 bolt with 1/2" tubes. More like 3/8".
    Dana 60 (fronts) 1/2" thick, Dana 44 (fullsize front) 1/2" thick. Waggy 44 (front) 3/8" thick, Ford HP 44 (front with cast on C bushings) 1/4" thick. Dana 60 (rears) 3/8" thick, and scout 44 (rear) 1/4" thick.
    PS, I build axles so I've cut into each one of these.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    anyone have thoughts about running thicker? say 1/2" thick for a 14 bolt?
  8. bluejeep
    Jan 9, 2004
    106
    Des Moines, IA
    I've discussed this topic with a (PhD) industrial engineer and his preference was bigger diameter thinner material for strength. 14 bolt has 3.375 OD tubing in a .375 thickness, which is more than adeqate for almost everything. Especailly if you're building it light, truss the stock 14 bolt and call it good. Not worth the effort and money it would take to retube it thicker. The only place it would ever bend anyway would be right up next to the diff, which is exactly the area a truss would reinforce.
  9. readymix
    May 30, 2004
    6,706
    26
    Did you browse through the 14 bolt bible because it states that it has 1/2" walll tubes. Never heard of .375 before.
