wandering blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scott87, Feb 7, 2001.
  1. scott87
    scott87 Registered Member
    Feb 7, 2001
    39
    basalt, colorado
    my 87 blazer pulls to the left when just coasting and slightly when braking. just replaced all the ball joints, installed new rotors and pads. yet it still wants to drift leftward?? it still has the stock shocks and leaf springs. maybe the shocks and bushings are worn? any thoughts/ideas would be helpful.
  2. achuskies69
    achuskies69 1/2 ton status
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=blue>sounds like your tires arent balanced
    <font color=orange> if you cant beat 'em, drive over 'em </font color=orange>
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have check to see if all you tierods are adjusted properly?
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  4. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Might want to replace your wheel bearings if nothing else helps..
    It's better to have it and not need it, than to need it and not have it.
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Consider adding the ORD steering brace............best $95 you will ever spend on your truck. Your wandering problem might be a simple fix, but it could be a frame flex issue.........that ends up leading to a frame crack. This brace triangulates the area to eliminate the possibility. A definite, noticeable improvement to my truck, which drove very straight to begin with, had no bump steer, and didn't pull.
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  6. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Check wheel bearing adjusment and tie rod ends.
  7. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Ok, ok. Nobody has metioned this yet but did you get a alignment? Start with the basics.
    Displacement, cubes, and did you say you drive a riceburner???
  8. Nrose07
    Mar 29, 2000
    267
    Salem ,Or
    And there is also the Mr.T theroy, "Fool, are you a big momma's boy with lots of gold like me? Then counter weight your passenger side!"
