Wanna Know bout some random stuff
Discussion in 'The Garage' started by Chevy305, Mar 1, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?catalogId=10002&storeId=10001&categoryId=76656&parentCategoryId=10763&langId=-1
    Check this out, its a carbed LS2 Crate engine. What do you guys think of it?
    Just curious, would the LS2 bolt up to the 465 bellhousing?
    Also if I were to ditch the tired 305 for a big block:smirk: is there anything I would need specifally that would differ from a small block? (I have no experience with big blocks only mousy motors)
    And lastly is there any difference between a regular 14 bolt rear and a duelly 14 blot rear? I can easily get a hold of a 14 bolt duelly rear and was wondering if it just the hubs that are different, and how to make it a normal 14 bolter.
  2. Big89Burban
    Big89Burban 1/2 ton status
    Jul 19, 2005
    143
    Magnolia, Tx
    I used to work on camaro/corvette (LS1) mostly and I have seen multiple guys with turbo 350's & 400 trannies in there cars. So there must be and easy way to bolt up the 465. If you get that LS2 all you need is a bigger cam/headers and I bet $$$ you would see damn near 500hp. :D
  3. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I thought the cam seemed a little small. Plus, who really likes manifolds?
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Must be nice having lots-o-money:haha:
  5. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Wanna Know
    Surely someone can answer the other questions.
  6. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Give more info on which 14FF you are thinking about using - what year ? what application did it come from ( Cab Chassis - wide or narrow / Fleetside ?
    For the most part the SRW & DRW hubs are interchangeable but the backing plate flange will be way too far away and will need some fab work.
    As far as SBC to BBC it will bolt up with no problems but you may want to use a harder durometer rubber motor mount or the aftermarket ones.
    You may have crossmemeber to fuel pump clearance issues ( some factory BBC engines motor mount bells/cradles are slightly taller.
    just about all accessory brackets are different ( I am assuming that you are using older "V" belt type brackets ) . Make sure you are using the correct flywheel/flexplate for what ever BBC you choose.
    Tom
  7. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    The 14 bolt is out of a 87 Chevy dually pickup. I don't know much more about it.
