Wanna put GM d44 knuckle and outers on Ford d44 axle housing
Discussion in 'The Garage' started by cmcracing, Jan 15, 2004.
  1. cmcracing
    cmcracing Registered Member
    Jan 6, 2004
    93
    Olathe, Kansas 66062
    Does anyone know if I can use chevy flattops and outers on a ford d44 axle housing, I have to have a for type axle housing but want to still be 6 lug. any info?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    The good thing about D44's between GM, Dodge and Ford is the fact the knuckle outers can easily be swapped in place of the others. I've done an older Ford open knuckled drum braked front D44 and converted with all GM parts but used Ford bearing hubs and rotors. Ford can use either the 1st or 2nd design parts from GM as long as the corresponding years of the designed parts fit one another.
    So, to make a long explaination short, yes, the GM parts will work on the Ford axle. /forums/images/graemlins/thumb.gif
  3. cmcracing
    Jan 6, 2004
    93
    thanks, any idea what year ford axle to look for, wanna put 1975 chevy stuff on it.
