Wanna see a running SubCummins conversion?
Discussion in '1982-Present GM Diesel' started by BurbinOR, Jan 31, 2005.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  2. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    Awesome!!! inspiration for all of us. I have an 84 c20 (first project to make it a K20) and it has a dead 6.2 diesel which I was planning on putting in a 454, but I'm really leaning toward a cummins 12v! :D
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Kutos to him for going with a 24v motor. :D He did a great job under the hood...
    his...
    Mine...
  4. eclipse
    Jan 1, 2005
    1,245
    Sparks, NV
    Whats the biggest difference in doing a 24v swap instead of a 12v swap? I know you have computer controllers. And what would you do with them on a 24v swap?
  5. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,038
    1,107
    Dallas
    A 24v comes with an electronic VP44 Bosch IP, so if one were sticking with that, he would plan on an ECM install, too. A P pump conversion allows for the use of a mechanical Bosch P7100 IP which simplifies electrical stuff. Also, 24v heads already come with the much sought-after 60 lb valve springs to which many 12v owners convert. Flow isn't clearly superior as a 12v head flows very close to a 24v - ported or not.
  6. eclipse
    Jan 1, 2005
    1,245
    Sparks, NV
    Haha still learning diesels here, so I"m a little confused. So your saying that you can switch to a mechanical pump on a 24v and that will eliminate some computers? So would this a conversion to a chevy easier?
    "Also, 24v heads already come with the much sought-after 60 lb valve springs to which many 12v owners convert. Flow isn't clearly superior as a 12v head flows very close to a 24v - ported or not."
    So the 24v heads have more flow with the 60 pound springs?
    Sorry I'm such a newb on diesels :p:
  7. AgDieseler
    Jan 25, 2001
    1,038
    1,107
    Dallas
    Any conversion that doesn't involve adapting 'puters to the truck is always simpler.
    The 60 lb valve springs allow for the use of a more aggresive cam profile. By themselves, they don't improve air flow to the cylinder.
    A 24v head is capable of flowing a greater volume of air than a 12v, but not by such a large amount that it offsets the extra effort required to adapt a P7100 to the motor package. Porting a 12v head, which is already setup for the mechanical pump, is a better hp/$ value than converting a 24v.
  8. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Actually the 60 lb springs are to keep the valves from floating when a governor spring change is done which results in higher engine speeds before defueling. They should be used with a stock cam as well.
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Oh wow. Marking for perusal/fantasy..... :D:D:D
