Want to burn out
Discussion in 'The Garage' started by joshone, Jan 28, 2007.
  1. joshone
    joshone Registered Member
    Jun 1, 2005
    26
    Inglewood, California
    I have an 89 blazer with 6" superlift, 35s, 350, everything else stock. I want to be able to do killer burn-outs. I was thinking of adding a front line-lock and also changing my rear diff. What size diff should I get? Does anyone have any experience with these ideas? Also, does anyone have any other suggestions besides a bigger motor?
    Joshone
    Hawaii
  2. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Assuming everything is running right on your truck, you should be able to burn the tires off if you are geared properly. Put some 5.13's in there and forget about the other crap.
  3. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    5.13's with 35's? That's way too low; I'd go with a 4.10, or at the lowest a 4.56. Line-locks aren't entirely necessary, but if you really want to burn the tires off, it is a nice addition.
  4. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    put it in lo range. leave your front hubs unlocked, and do a brake stand
  5. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    get a gov lock 10 bolt....with 3.42's and then some 38's.
    Smoke em if you got em.
    Ok seriously why the big burn out deal...this is such a waste.
    If you must....get a 14bff with a detroit....bulletproof.
  6. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    10 bolt sucks ive blown to from burn outs my 87 3.73 gears 350 14 bolt semi float open will get one tire smoking like crazy and ive left 20 ft marks throw it in 1st if not it tries to shift to 2nd
  7. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    Yeh, that is exactly what I meant....it was a joke K?
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    :deal:
  9. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    naw i wasnt really referring to what you said i could tell you were joking i was saying what your were 3/4 ton lol gets the job done
  10. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    call me stupid but ... i dont get it?
  11. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Try a little punctuation... Run-on sentences like that may make sense to you when your typing them, but it's annoying as he!! to read...
  12. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    yea im a lil bad on that whole ordeal ... lol
  13. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    x 53:bow:
  14. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    And if you really want to wow the crowd, hook up a pressurized water spray nozzle in the wheelwell. A little water goes a long ways.
    Maybe even into the crowd.
  15. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Never toasted a 10 bolt but I killed to 700s that way im pretty sure...
    Time for Pic Whoring
  16. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Ahh, man... I used to run a bleach tank and washer pump in my trunk with nozzles to the wheelwells in my hotrods back in the 80's.... fun, fun, fun.....
  17. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    You think bleach is bad, we used to pour used motor oil on the tires. You have never seen so much smoke. The best part is you never ruin your tires, you just burn off the oil. So easy a Ford can do it.
  18. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    LMAO:haha: :haha: :haha: :haha:
  19. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    Did the bleach ever bubble the sidewall rubber? I had that happen to a set of M/T tires on a Chevelle.
  20. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Nah, but if you used it a bunch the tread compound would get kinda funky... :doah:
    That was a trick setup.. Sitting at a light, little flip on the momentary toggle... I was kinda proud that I thought of it, hadn't seen it done...
    Being all James Bondish... :haha:
