Want to install a rear swaybar on my 2wd Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by littlebubba, Apr 8, 2002.
  1. littlebubba
    littlebubba 1/2 ton status
    Mar 31, 2002
    106
    Clinton Township Michigan
    Does anyone know of a factory rear sway bar that bolts right up on a 2wd Blazer with the factory 12 bolt rearend? I also want to install a posi? I thought about looking for a Suburban rearend with the factory swaybar and limited slip gears, will it work in my 81 C5?
  2. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    should work, you can call hellwig or LMC they should run you about $100 or so from what I've seen, was on my to do list when I had my truck but sold it and not putting one on the blazer so...good luck
  3. littlebubba
    Mar 31, 2002
    106
    I thought a Suburban rear and swaybar would work, but I need to know what years and if they were trailing specials or something along those lines so I can find one.
  4. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    make sure you measure the spring perches and 3/4 ton 2wd came with a rear sway bar as an option!
  5. littlebubba
    Mar 31, 2002
    106
    Been looking under alot of GM vehicles lately to find a swaybar that will work. Looks like a rear swaybar off a 454 SS pickup might work. Haven't been able to find a 73-91 Suburban with a rear sway bar yet. Stay tuned, I need to take some measurements.
