Want to make a multi mount for warn 8274
Discussion in 'The Garage' started by 53chevy, Aug 1, 2005.
  1. 53chevy
    53chevy 1/2 ton status Premium Member
    Dec 29, 2004
    369
    7
    pitcairn
    What is the best way and what type of materials will i need.I've seached but i can only find ways to fix them.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It will have to be a pretty heavy chunk, due to the way the winch mounts. The front edge has to be tall enough to bolt the winch in place and thick enough to handle the stress of winching. If it twists under load it will cause the winch drum to bind. :eek1:
  3. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    I'm going to use 1/4" or thicker, also i have a hitch i'm planning on cutting down and just put that betwwen the rail in the front. Also i'm trying to have no drop for the winch. Any ideas or drawings will help thanks.
  4. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    I have made a multi-mount for a WARN upright, and I have but 1 thing to say
    :eek1: :eek1: :eek1: :eek1: HEAVY!!!! :eek1: :eek1: :eek1: :eek1: U have to make it sooo strong that it's 2 much for 1 person to put in and take out :doah:
    I made a replica of the center part of a WARN winch bumper just wide enough for the winch, and put that on an insert.
  5. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    I am going to use 3/8 plate c channel..... will have pics..... :wink1:
  6. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    A multi mount with an 8274? :confused: :doah:
    With the winch itself weighing in at (according to Warn) 110 lbs + whatever the mount will weigh just seems impractical. Assuming you are Hercules and the weight doesn't matter, do you really think a reciever mount can deal with 8000 lbs of pull? I'm sure anything less than a perfect straight pull would bend things out of shape.
  7. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    I got the winch for a good deal and the rear end already has the wiring for it. I'm a big guy i'll be able to move it in the range of 200-250. I'm planning on a stong front end.
