Want to put 3/4 ton 14ff into 1 ton chassis. Will it work?
Discussion in 'The Garage' started by Klink K5, Sep 3, 2004.
  1. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    Ok first of all I know the spring perches are diffrent and so are the shock mounts. Anyone cut them off and welded them back on with sucess or is it a nightmare. Seems to me everyone is throwing 1 ton rear axles in 1/2 and 3/4 ton stuff, what did you do to the stuff you cut off or did you reuse it? Let me know, Klink Just dont like /forums/images/graemlins/hack.gif stuff up like that /forums/images/graemlins/rolleyes.gif
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    No biggie just grind the welds and wack it with a BFH and they pop off. I have a 2wd 14bff and the shock mounts hung way down. took alost a half hour to move them /forums/images/graemlins/waytogo.gif
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i have never had much luck getting them off w/out tearing them up, but idon't have any patience
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I've pretty much destroyed every set I've cut off.
  5. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    the other option is to score the 1ton spring hangers to mount on your frame. thats the only difference. they move the springs in 1/2 inch on each side to clear dually wheels.
  6. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    destroying my set in the process right now. there is a 1/8th inch space in between i cut into between the axle housing and perch and use bfh and screwdrivr to get them off in the middle. good luck a PITA if you aske me, would have left them if I hadn't hacked them so much before i knew what i was doing. Good luck going to dinish mine tomorrow once the liquor wears foff. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
