Want to put a 4" on a '78 K5
Discussion in 'The Garage' started by schef37, May 23, 2002.
  1. schef37
    schef37 Newbie
    May 23, 2002
    Want to put a 4\" on a \'78 K5
    I am buying a 78 K5 and want to put on a 4" lift. I would like to know if anyone makes a COMPLETE System for this and which companies are the best. I would like to use new springs front and rear for the lift, no blocks, it has to be bulletproof. I also plan on running 33" BFG radial all-terrains. It will be a daily driver year around and heavy use in the winter with a snow plow. It will not see much off road use but will be used to plow so the lift kit has to be strong. I don't want parts from here and there just everything in one box everything I need to do the lift (if possible). If this is not possible can you point me in a direction to get the most complete available? Thanks
  2. buick528
    buick528 Registered Member
    May 3, 2002
    55
    montgomery,il
    Re: Want to put a 4\" on a \'78 K5
    superlift ,skyjacker,rancho.check out offroad design they have some good lift options.
  3. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Tuff Country has a compleat system front and rear springs with shocks you can get them in either easy ride or heavy duty springs.
  4. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    I've got 33x12.5s on My 78 with no lift at all. Maybe all you need is an add-a-leaf for the plow.. I used mine in heavy snow for two months and had no problems at all.
  5. 78Jimmyish
    78Jimmyish 1/2 ton status
    Jul 28, 2001
    137
    Rhode Island
    I wouldn't put a 4" lift on if you're planning on plowing. 2" at most. And go with one of the stiffer kits (Rancho or Rough Country.) I plowed with no lift and 31's but a small lift and 33's would be cool too. The higher you are, the more strain that big lever arm is going to put on parts.
