Want to see 37'' tires with a 6'' lift?
Discussion in 'The Garage' started by camok5, Jun 15, 2005.
  1. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I am running 35'' pro comps right now with a 6'' lift but want to get an idea of what my blazer would look like with 37's( doesnt matter what kind ). Plus if anyone is running the 39.5 iroc radials with a 6" lift I would love to see those also.
  2. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
  3. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    awesome burb, thats about the exact same set up i want my k5 to be.. right now i have 4" lift, but i want to bring it up to 5-6 and stuff some 39's under it. what gearing do you have and how is it on teh highway going up some hills? sry for the hijack
  4. 4trolls
    Nov 13, 2002
    190
    vancouver wa
    hey thanx! it has stock 350/sm465/205 4.10 gears. I wont win any races going up long whindy mt. roads ,but its well within "ok" . on the flats it feels the same as it did with 33" but Iroks are not round :D I realy feel like I lost nothing and gaind soo much off road
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    As long as we're hijacking this thread - how much cutting did you have to do, do you have any rubbing problems and what size/offset wheels are you running?
  6. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    6" BDS all spring lift & 37" SSR's
  7. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    No Iroks, but 6" and 39.5" boggers.
  8. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    [​IMG]Here is 6" with 38.5 SX's
  9. 4trolls
    Nov 13, 2002
    190
    vancouver wa
    I had to cut about 1" off the top of the fenders and about 2" off the rear and I can make it rub,I am on the look out for some 4" lift springs for it because I need 2 more inches and I dont want to give up my inner fender wells. The rims are the stock ones that came on the truck
  10. jmd4x4
    jmd4x4 1/2 ton status
    Apr 4, 2005
    137
    Rosenberg TX
    Cegusman is that your old orange blazer made over? Were in katy do you live? I would like to get to gether and check your K5 out a little closer. Maybe grab lunch or something. Let me know something.
    later
    jmd
  11. jmd4x4
    Apr 4, 2005
    137
    Rosenberg TX
    Ok never mind, I just saw your build up. So that is the blue blazer you have been working on? Have you got it running yet?
    later
    jmd
  12. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    what back spacing are you running. Just curious I'll be going to 38.5 " boggers and they are 15" wide, I have 4" right now Just worried it will hit the tie rod.
  13. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Those are 15x8 wheels with 4.25" backspacing, It took alot of grinding of the calipers to get them to fit. But I like my tires tucked back under the truck.
  14. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I am at N Fry rd. @ Morton, More like Fry and I-10. The K5 is still not running, need to run the new wire harness, but need to finish the interier first. Send me an email texasmuddslingers@houston.rr.com, lunch or just to hang out is cool.
  15. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    6" TC with 38 tsl radials :D
  16. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    6" and 37" boggers:
  17. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    So does anyone have any regrets running 37" thinking they should have gone bigger? Plus how do the radial irocs run on the street and how long do they last compared to the ssr radials?
  18. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Never run Iroks but I think you are better of getting the ssr's. Should get many more miles out of them since the tread width is not so far apart.
  19. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    how about 38.5s on 4" lift NO TRIM!!!!
