Wanta raise my truck more.
Discussion in 'The Garage' started by sho_shane, Jan 25, 2007.
  1. sho_shane
    sho_shane Registered Member
    Dec 27, 2006
    51
    Leonard Tx
    OK I have a 4" susp lift and a 3" body lift on 35" tires. Im going to be driving this truck daily and just got the tires. So a bigger tire not what im looking for. Also since im going to drive it every day I dont want a huge tire under my truck. Ok so I want to raise my truck up some more tho. I see all the guys around here and my truck is tall but im not the biggist lol. I want to be the guy every one looks up to lol :D So what can I do to my truck to get it up alittle more?
  2. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    anything bigger than what you have would be rediculous with 35's imo. Your truck is taller than mine and i have 39.5's
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    X2 but Im on 37s
    Ira
  4. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,851
    280
    Truckee, CA
    You won't find many on here going for height just for looks. Its not really that safe. If you are just keeping the 35',s you have more than enough lift already.
    But if you insist, you need larger lift spring, front and rear. Only real way to do it. Unless you don't have a shackle flip in the rear, that would net you 4", and u could get 4" taller spring sin teh rear
  5. sandawgk5
    Oct 28, 2003
    6,881
    Super lift makes a swamprunner kit that is 12". It combines a spring and a block in the rear so that kit with a 4" shackle flip should net you 12" suspension with your 3" BL that makes 15". You could run 49 Iroks and not trim at all with that lift as it wont flex at all.
    With only 35s I recommend you stay with what you have maybe even take the BL out.
    Also with a huge lift in a K5 the driveline angles really start to suck.
    Ira
  6. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    yeah personally I think you should leave it like it is. I ran 7in lift with 35s on my old truck and thought it was too tall. I could still stuff the tires hard enough to make them rub though:D .
  7. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    another thing too, raising it higher will add to the wind resistance and make a truck that is already like a brick wall less aerodynamic thus killing gas mileage even more.
  8. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    sounds like someone has insecurity issues :crazy:
    listen to what these guys are saying, you lift it anymore without larger tires, it's gonna look funky,but then again you did say you want to be the center of attention:p:
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    for refrence, there's 6" suspension, and 3" body on 35s. anybody recognize the truck?
  10. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    starts with a t and ends with a y
  11. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    834
    Pinckney, MI
    damn beat me too it..
  12. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
    The posterboy for insecurity....
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you guys got it... truck used to be known as "Pee Wee" :haha:
  14. sho_shane
    Dec 27, 2006
    51
    Leonard Tx
    Well I cant see the pic. Im not a member yet. But maybe if i just went with a 37" or so. That would give me alittle more right?
    I dont want a truck that dont perform I just want to to look cool to. :)
  15. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Sell your tires and buy some 42s. Look in the garage forum under how will my truck look with xx lift and xx tires.
    And swing the money for the membership.
  16. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    start thinking about regearing if you are going to keep going up in tire size. just slapping 37's on is going to cut into the performance of your truck. If you do go with bigger tires and you need a little boost in height then a zero rate block is one way to get an extra inch.
    and stop putting LOL at the end of your own sentences.
  17. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    It will sit a little taller but just puttin on a slightly bigger tire won't help much.
    If I wanted to look cool and was working with your truck, I'd spend my money on finishing the body work and paint, level out the rear end, put the correct mirrors on it, and polish the rims for some of that "I want to look good" style your after.
  18. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    look into male enhancement pills? if you need help, viagra will help raise it up some more.
    you can swap in 6", 8" or 10" or 12" springs if you want. i have a picture of mine when it used to have 8" lift and 35's. looked kinda silly. if i was you, id look into gettin 37s or 38s with your current setup.
    first pic: 8" lift and 35's
    second pic: ~9" lift and 39.5's
  19. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    Dude, you don't want to be like this:
    (12" lift and the 33" BFG's I had on it when it was stock.)
  20. sho_shane
    Dec 27, 2006
    51
    Leonard Tx
    Your right. I dont want my truck to look like that :)
    Ill start working on some body stuff...
