WANTED 14BFF Dually
Discussion in 'Parts & Trucks Wanted' started by Pookster, Oct 25, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Friend needs a pre 91 14B dually axle.
    PM me if you got one.
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    You mean a cab/chassis 14FF axle? or a Dana 70 Dually axle? Pre '91 would not have used the 14FF in the Dually pickups.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Got one! Problem is...how does it get to you? /forums/images/graemlins/thinking.gif
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Actually my friend has a 14bff in his 85 dually.
    After 84 they started to put some 14bff as well as the D70, I believe the GT5 was the 14bff and the GT8 was the D70 both 4.10 gears.
    I just bought an 88 crew cab that also had the 14bff.
    /forums/images/graemlins/dunno.gif
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    GT5 and GT8 are ratios, not axle models, im sure you know that, i said it anyways
    and i see more 14 bolt duallies than dana duallies big time, i ive only seen two or three dana dually trucks ever, everything else has been 14 bolt
    dana was only under some 80-up dually pickups i know, yeah, i have gm specifications sheets showing illustration of them and listing 70 axle and rear bar and all,. 3+3 cab
    apparently some running around now were originally not pickups or something
  6. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I dont think he cares, he just wants something that will bolt in. Its 2wd, so he doesnt care much about gears are even in it.
  7. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Thats a good question. Any ideas of forward air?
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you read carefully on the GT5 and GT8 description, GT8 is the HD.
    The only difference between D70 and the 14bff is the axle tube diameter, and the D70 in dually form is the HD.
    That led me to believe that the GT8 is the D70 dually.
    Why else would they have 2 codes for the same ratio.
