Wanted: 14BFF open carrier (4.56 & up)
Discussion in 'Parts & Trucks Wanted' started by thebigdaddyof2, Apr 16, 2003.
  1. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Anyone have a 14BFF, (4.56 & up series) open carrier for sale? I need only the carrier please.
  2. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    TTT.
    Anyone?
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Do you happen to have a Gov-loc for 4.56's?
  4. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Yes....well kinda. I had a gov locker. Way back, I completely disassembled it and welded the spiders up. After the last Potosi Run, I found that the spider gears actually cracked/shattered around the welds. I have since modified the side gears, added blocks of steel and rewelded the unit to be usable spool.
    Because of the occational street driving, I think it's time to try a detroit though.
  5. outlaw612
    Feb 11, 2001
    2,342
    I was hoping you had a good Gov loc. Id rather have a gov loc rather than the welded rear since its a DD, but I cant find a gov loc for the 4.56's. If I can find a govloc and someone to setup the gears again, I could give up the open carrier Im running now.
  6. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I just talked to " mplogic " and he has a spare gov lock, he lives in az too, I also mentioned this too him already so just pm him about it /forums/images/graemlins/thumb.gif
  7. outlaw612
    Feb 11, 2001
    2,342
    Thanks, will do!
  8. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Matt,
    If you buy his gov-loc, I'll buy your open carrier.
    On the gear setup, swaping the carrier should be a no-brainer in the 14BFF (if you don't change the pinion assembly). The only thing you will adjust is the backlash- which is real easy.
  9. outlaw612
    Feb 11, 2001
    2,342
    I talked(pm) to him today, and it was the wrong carrier. it was the 4.10 and numerically lower carrier. If you come across a gov loc for 4.56's, Ill trade ya.
  10. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Good luck finding a gov lock for 4:56's. Your best bet is just to get one for 4:10's and buy a thick gear set in 4:56.
  11. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I'm on the lookout....
  12. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I still need an open 14BFF (4.56) carrier.
    I would consider buying a 14BFF, 4.56 gear setup and an open carrier-
    if the pinion is complete with the pinion support and the shim is in tact.
