WANTED: 3/4 ton calipers...........
Discussion in 'Parts & Trucks Wanted' started by 84CUCV, May 16, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    How much? New/used? Thanks mike
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I've got some off a D44.....$25 + the ride?
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    will it work on the 10b? Is there even a differnce? I think they are the same. A lot of miles on them? thanks mike
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    They're the same as far as fitting in the bolt-holes and rotor-thickness. The difference in the calipers is in the banjo bolt size. It's different for 10 bolts and D44's...1/2" and 7/16" respectively, I believe.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    he is correct, physically they are the same exact caliper, the banjo bolt is the diff....D44 is 7/16 and 10bolt is 10mm
    Mine are complete(minus the banjo bolt)and it even has 60% pads included. These calipers are prolly 3 yrs old.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    neighbor of mine has an 80s 4x4 chevy coming tomomrrow, says he wants 150 for it minus drivetrain, maybe i can get calipers off it before it goes to scrap cuz im pretty sure no one will buy it and it will end up going on trailer ride to shredder yard in peoria, make an offer plus mail from 62656 and ill see if i can get the calipers, it will be 10 bolt 1/2 ton truck
    thanks
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Will calipers from a 1/2 ton ten bolt work?
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i dunno, maybe not, hmm.. the truck should be next door by the time i get back here at 1:00 later today, ill measure like rotor thickness and distance from mounting bolts if we dotn find out for sure that 1/2T wont work on 3/4T, or event he truck coming here might be a K20, dont know,. hmm
    good luck /forums/images/graemlins/laugh.gif
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    yes, 1/2ton calipers will work on 3/4ton rotors, they are the same caliper /forums/images/graemlins/thumb.gif
  10. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    wow guy at the parts store said 70 for one and they are not the same. thanks guys
  11. motofool
    motofool 1/2 ton status
    Apr 7, 2004
    361
    DFW tx
    anyone got some with parking break setup for a 14bolt disc swap?
  12. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    What kind do you need i can look around. year? model?
    mike
  13. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    he looking for the 76-78 caddy eldo rear calipers
  14. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks guys i got calipers. mike
