Wanted: Misc 700r4/208 parts, shifter, mounting etc
Discussion in 'Parts & Trucks Wanted' started by Xtremjeepn, Feb 18, 2007.
  1. Xtremjeepn
    Xtremjeepn 1/2 ton status
    Jan 17, 2006
    437
    Saddle Rock, CO
    I seem to be missing some parts to install a 700r4/208 in my 74 chevy truck. I need a shifter, transmission mounting bracket/cross member, front drive shaft.
    OR
    I need a spacer to make my 203 fit the 700r4.
    303-359-7469
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I have a driveshaft I'd sell for $40 and a shifter missing the screws to hold it to the floor I'd sell for $10. For the crossmember is your truck a 1/2, 3/4 or 1 ton? 1/2 and 3/4 ton use the same crossmember and 1 tons use a different one (at least in 74). Are you needing the tranny/tcase adapter too?
  3. Xtremjeepn
    Jan 17, 2006
    437
    Saddle Rock, CO
    I took out a th350/203 and went to mount the 700r4/208. My crossmemeber falls about 4 inches too low to meet up with the transmission. Like there is part of the 208 adapter missing. (truck is a 3/4 "camper special").
    So the first thing I need to figure out is how this is supposed to mount.
  4. kennyw
    Jun 9, 2002
    13,224
    94
    Are you trying to reuse the original crossmember from your TH350/203? That could cause that problem. There is also a rubber isolator between the tranny adapter feet and the crossmember. Do you have that?
  5. Xtremjeepn
    Jan 17, 2006
    437
    Saddle Rock, CO
    Yes, trying to reuse the crossmember. Nothing I have read here indicated switching cross members. I do have the rubber mounts. But maybe there is a different one?
  6. Xtremjeepn
    Jan 17, 2006
    437
    Saddle Rock, CO
    Do you have pictures of the 208 shifter? Idea what it would cost to ship to 80224?
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    There are 2 kinds of 208 adapters, tall that works with your old cross member, and short which you have now and need a different cross member.
    I have both cross members and both adapters, let me know if you need either.
    As for the shifter I have one but Kenny is first and mine is not that cheap :D
  8. kennyw
    Jun 9, 2002
    13,224
    94
    Crossmember is your problem. There are different crossmembers for the 700R4 in the mid 80's. The '74 crossmember is basically straight across with a slight rise to meet the frame. The 80's they had a W shape most commonly so it rose up in the center to meet the tranny adapter. If you get one from that era off of a 1/2 or 3/4 ton it should fit better.
    I can get pics later... right now its installed in my truck and coming out in favor of a 465/205.
    I even have a crossmember you need as well coming out soon... I could do a package deal on the crossmember, front driveshaft, and shifter for $100 shipped.
  9. kennyw
    Jun 9, 2002
    13,224
    94
    Just remember mine is cheap because its missing screws... nothing you couldn't dig up yourself, but its a pain to get into 4wd when the base plate moves on the floor. :haha:
  10. Xtremjeepn
    Jan 17, 2006
    437
    Saddle Rock, CO
    I guess the question is "how soon" will you have them all out?
    Thanks for the help guys.
  11. kennyw
    Jun 9, 2002
    13,224
    94
    Driveshaft is already out... shifter would take all of 2 minutes to pull since there are no bolts. Crossmember I would just need to double check and see if I have an extra laying around, I might still have one if it didn't go with the last load of scrap metal. If I don't have the extra crossmember I wouldn't have it out for probably a month as I need to keep the truck mobile until I'm done rebuilding the 465/205.
  12. Xtremjeepn
    Jan 17, 2006
    437
    Saddle Rock, CO
    I might just have to build a custom x-member. That may be the easiet way. Need to get the truck mobile pretty soon.
    I will let you know about the shifter.
