Wanted: pointers on steering box weld in kit
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by spearchucker, Apr 9, 2004.
  1. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I've got an 89 Jimmy and getting ready to install a weld in frame repair kit and install the brace from ORD. There aren't any frame cracks that I can see. I've got a welder coming over to weld the kit in. I'm just wondering what needs to be removed and prepped before he comes over. Also any problems, hints or tips that you care to share would also be alot of help. /forums/images/graemlins/ears.gif /forums/images/graemlins/thumb.gif
  2. gm4x
    gm4x 1/2 ton status
    Apr 6, 2004
    347
    Pendleton, Indiana
    go to the front page here & look @ the project vehicle. There's a link that shows it. Being new here I just happen to run across it last night /forums/images/graemlins/waytogo.gif
  3. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
  4. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Make sure to get the steering shaft mated to the gearbox as you install the gearbox. Once the gearbox is installed, the shaft can't be attached. Also, make sure the steering shaft is oriented properly to the gearbox. On my 83, it could be 180 degrees out and you'll never know until you find the steering wheel upside down. Everything has to come apart to correct this situation.
    I just did this, minus the weld in part, this weekend. Let me know if you have a question I can help with.
  5. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Make sure you have a BF'n hammer, youll need it.
