Wanted! Replacing a NP208 with another 208 instructions.
Discussion in 'The Garage' started by juanblzer, Apr 19, 2004.
  1. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    I'm a t-case swap virgin.
    Will someone please give me the most detailed instructions they can afford. I can turn a wrench, a ratchet, swing a hammer etc. Do I need any special tools? Snapring pliers? THanks for all the help.
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    All youll need to do is drop the rear shaft, unscrew the speedo, unplug the 4wd light plug, take the pin out of the shifter linkage and remove the 6 bolts that go to the adapter. If the support rod is hooked up youll need to remove the 2 - 1 1/8" (I think) bolts. Then the t-case will just slide off. It light enough to just bench press it down to your chest and roll it off to the ground.
    Once it off, just do it all in reverse to install the new one.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    9/16 ratchet wrench makes those adapter bolts supremely easy. By most grown male's measure a 208 is "light"(in relation to other truck parts) and doing like outlaw said is fine. Remember to use a gasket between the adapter and tcase and some RTV, believe me, when they leak is a pain in the butt.
  4. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    is the gasket an item I can get from the dealer? Thanks for the info fellas.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yep. I tried just RTV last time i did it, and truthfully I didn't get a really good bead on it but it leaked pretty good.
  6. outlaw612
    Feb 11, 2001
    2,342
    Ive always just used silicone, but you could use a gasket also.
