Wanted: Stock 56" truck springs
Discussion in 'Parts & Trucks Wanted' started by CK5, Nov 20, 2001.
  1. CK5
    May 19, 1999
    21,625
    702
    CO
    Wanted: Stock 56\" truck springs
    Looking for a pair of stock 56" rear springs from GM truck, would like newer ones with teflon inserts if possible.
    Steve
    Director of Global Expansion
  2. Re: Wanted: Stock 56\" truck springs
    I have a set of 56" 3/4 ton springs from I think it was a 1990 Chevy truck. They have the teflon pads and 7 leaves, 8 if you count the overload too.
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>I Like my Burb'n on the ROCKS !!
    <font color=black>Imported to Kentucky through military channels !!
  3. CK5
    May 19, 1999
    21,625
    702
    CO
    Hmmm, I was looking more for 1/2 ton (softer), when did the IFS trucks go to 63"?
    Steve
  4. Re: Wanted: Stock 56\" truck springs
    Not sure when they went to 63". I have been holding on to these to maybe throw under the Burb and loose a few leaves to soften them.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have some 56" long 3/4 ton springs, but they are off an '80 truck. Probably don't want these as they don't have the teflon inserts. Oh well. [​IMG]
    Didn't the 63" long springs start the same year as the IFS, in '88?
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  6. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I've got a set of 56" F150 springs like marv springer used on his shackle flip. I know it's not really what you're looking for, but thought I'd throw it out there. They're super soft. I went to '89 rear springs so I'm not using them.
    Sherman, Tx
    <font color=red>The blazer's almost on the road....anyone got tree fiddy?</font color=red>
  7. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I have two sets. One is off a 74 K-5 and has add-a-leafs in it. The other is off a 70 K-5 completely stock and soft.
  8. FullsizeRocker
    FullsizeRocker Registered Member
    Nov 24, 2001
    31
    Rock Mountain,WY
    FYI: Nothing but 1 Ton units from '73 to '80 had 56 inchers on 4x4's. A bunch of heavy 3/4 ton 2wd's had them and no 1/2 ton and Blazer's had them at all until 1988. As a matter of fact, Blazers didn't even get them until 1992 when they went to the IFS units. As far as I know, all of the 1/2 tons from '88 &amp; up had 56 inchers, and all of the 2500 (light 3/4, heavy half depending on what you call them) and 3500 trucks had 63 inchers. Unfortunately, there are a ton of 56" springs laying around here and are all 2wd 3/4 ton versions, but then you end up with a harsh ride;Unless you do what I have done, take the bottom two leafs(overload included) out of the packs and compensate for lift elsewhere. I have built a custom drop front hanger, utilized a shackle flip and 2" extended rear shackles for a total of about 5" in the rear, and they let my 38's flex about 5 inches on either side past where the top of the fender used to be. I haven't measured, but I have to be getting somewhere in the neighborhood of 17-20 of wheel travel. The down side is that I imagine I'll be replacing those springs often, but hey they're a dime a dozen!!! Just my $.02
    If you can dream it, you probably can't afford it!!
  9. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    The only thing I'd like to add (primarily due to my limited knowledge) is that my 88 Burb has 52" springs. They suck!! From what I understand, sometime in the 88 model year they changed. That is why some 88's sag in the rear &amp; some don't. Just my $0.02.
    BurbLover
  10. CK5
    May 19, 1999
    21,625
    702
    CO
    Thanks guys, I think I am going to go F-150 here local when I do this.
    Steve
