Warm up trouble - almost cuts out on me
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Steve88, Aug 4, 2000.
  1. Steve88
    Steve88 1/2 ton status
    526
    Sunny Arizona !
    Just started within the past two weeks. Has been fine otherwise:
    For first 5 - 10 minutes of driving if I step on it at a light it'll almost die on me. Once I get going it sounds/feels o.k. Just at take-off. I have to pump it a bit to keep it from stalling out, or just take off very slowly. Once warmed up it seems o.k. Haven't changed anything on it recently.
    Any ideas? Fuel filter or pump? (but it's o.k. once warmed up, so I don't think it's that.)
    thanks!
    88K5 stock 350TBI, 111000 miles.
    <font color=red>Steve88</font color=red>[​IMG]
    88K5 Silverado
  2. Kelboski
    Kelboski 1/2 ton status
    306
    Mcdonough,Ga
    mine did the same, gradually got worse, and it was the fuel filter, my gas tank had rust in it and it began to clog the filter slowly, i had to have the tank cleaned and a new filtr put on and that fixed it
    Kelboski....mines a 4 barrel though...not a tbi
  3. Steve88
    526
    Sunny Arizona !
    I might do the filter this weekend for the heck of it. Probably needs it anyway. Can't understand why it would work ok after warmup though. But what do I know...thx
    88K5 Silverado
  4. Kelboski
    306
    Mcdonough,Ga
    i don't understand the warm up thing, since its a tbi....someone here will know though. sorry i'm not much help
    Kelboski
  5. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    Mine isn't tbi but I have a bent pushrod and a bad camshaft...the max I can get it to go is 75
    <font color=blue>If its too loud, your too old.</font color=blue>
    http://82Jimmy.coloradok5.com
  6. Steve88
    526
    Sunny Arizona !
    Well here's an update:
    Replaced the following: Dist cap and rotor, fuel filter, O2 sensor, upper and lower air-cleaner gaskets. Checked all the vacuum lines, everything looked ok. Pulled the computer codes. 44 came up (which says lean mix reported from the O2 sensor.) Would this cause a bog when it's warming up? Remember it's a TBI. I'm going to do a diagnostic on the new O2 to make sure it's working. Supposed to read 100 - 1000 millivolts when running and warmed up.
    Any other ideas?
    thx
    88K5 Silverado
  7. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
  8. realsquash
    Jul 12, 2000
    778
    SE WI
  9. Steve88
    526
    Sunny Arizona !
    What's a CTS?
    To answer your other question, the Service Engine Soon light only came on one time, last week, for a minute and I hadn't seen it before then - ever, nor have I seen it since then.
    (Already changed the fuel filter...)
    88K5 Silverado
  10. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Coolant Tempature Switch (CTS)
    AZBlazer
    1979 K5
    1976 K5 Chalet
    1972 K10 Suburban
  11. realsquash
    Jul 12, 2000
    778
    SE WI
  12. Steve88
    526
    Sunny Arizona !
    Ahh. OK. For $6 it can't hurt to change it.
    Hey AZBLAZER, shouldn't you be at work? Heh-heh!
    88K5 Silverado
  13. Steve88
    526
    Sunny Arizona !
    By the way - where does it go and what does it do?
    My engine seems to be cooling fine, and the temp gauge is reading fine.
    88K5 Silverado
  14. Whii338
    Whii338 Registered Member
    Apr 24, 2000
    35
    Steve,i had similar problems with my '88 and after replaceing a number of things...fuel filter etc...it turned out to be the egr valve......just my 2 cents...reach under the egr and try to move the diaphram with your finger tips if it is sticking or hard to move then it prolly needs to be replaced....hope that helps..like i said it worked for me but the other fellas are also correct.
  15. Steve88
    526
    Sunny Arizona !
    Yeah, I took a good look at my Haynes manual last night, and along with the EGR valve, and the CTS, I've got a whole bunch of other things I can now check for this weekend. Thanks to all and I'll provide an update when I figure it out.
    88K5 Silverado
  16. Kelboski
    306
    Mcdonough,Ga
    you're spark control module, or a bad ground could do it also.........the codes would tell you though
    kelboski
  17. Steve88
    526
    Sunny Arizona !
    Plot thickens...
    I checked the EGR valve this morning and it moves freely, BUT found that the other end of the vacuum line was connected to a broken nipple. And we know how much those hurt!
    No really, I have the following 2 questions:
    1) What is that thing it's connected to called and/or part # for it? (EGR solenoid?) Autozona and Checker couldn't tell me over the phone. What should it cost? It has the vacuum line from the EGR connected to it, and a vacuum line from the TBI connected to it, along with a wiring connector.
    2) There is actually a third vacuum nipple on this same thing, that was above the broken one. Is there something (even a plug?) supposed to be connected to this? I don't see any dangling hoses.
    Thanks!
    88K5 Silverado
  18. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Yes this is the EGR solenoid. Don't think anything else is connected to this.
  19. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I think the x-tra port on the EGR solenoid is just an atmospheric vent. When it's on, the solenoid connects the EGR valve to the vacuum source from the throttle body. When it's off, it connects it to this vent. If it just blocked it off, the EGR valve would not close, or it would close very slowly. If I recall, on my truck, the vent had a foam filter over it that looked like a little microphone cover.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  20. Steve88
    526
    Sunny Arizona !
    OK. Well I did in fact replace that EGR solenoid, and even took the EGR itself off to check it's usability. That was over the weekend and I didn't see any positive results from the new EGR solenoid, and the valve itself seems to be working properly. Even tested my O2 sensor (remember I just bought it) on my multimeter and it read as it should have (.1 - 1 volts).
    Then I went ahead and changed out that CTS (coolant sensor) and wah-la problem went away. Sure enough, like AZBLAZER and the others had mentioned, it seemed that even though I wasn't pulling the code for a bad CTS, the CTS must have been reporting a bad temp to the computer and leaning out the mixture to the point that it would cut out when I needed it at take-off.
    So the $9 CTS ended up fixing the problem from what I can tell. Thanks all and hopefully someone besides me will learn from this post.
    88K5 Silverado
