Warn 35 spline hub FUSE pn. needed
Discussion in 'The Garage' started by JK5, Aug 25, 2003.
  1. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Subject says it ALL!!! For Hub PN. 62672
    Jerry /forums/images/graemlins/smile.gif
  2. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I just called Warn....
    They don't make fuses for the 35 spline!!!! /forums/images/graemlins/rolleyes.gif
    I guess I'm buyin an extra set of hubs!!! /forums/images/graemlins/eek.gif
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Why not buy a set of drive flanges?
  4. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Who sells them??? TODAY!!! /forums/images/graemlins/wink.gif
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The hub fused for the 10-bolt and Dana 44 axles were designed to protect the axle shafts and u-joints. These fuses were just the existing drive gears that were machined down to be weaker. Basically the fuses, which are cheap and easy to replace, would break first.
    I guess the reason they don't make them for the 35-spline Dana 60 (Do they make them for the 30-spline stubs??) is that the shafts and u-joints are so beefy most people don't have to worry about breaking them.
    If you can't get the fuses you need, then you should be concerned about needing spare shafts and u-joints rather than hubs /forums/images/graemlins/confused.gif
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    You can get Warn drive flanges from www.4wdfactory.com or probably anywhere that sells Warn parts. I believe the part# is 39346(from the article Steve put up on the 35 spline shafts)...
  7. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I called them already...
    I should have asked about the flanges.. /forums/images/graemlins/blush.gif
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    Call again! /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  9. Orange Crush
    Orange Crush 1/2 ton status Premium Member
    Mar 6, 2003
    440
    St.Stephen S.C. 29479
    Would you rather break a hub or axle shaft or u-joint? I have drive flanges of the warn flavor on my rig and i broke both axle u-joints. not at the same time but on the same trail. Beware of NAPA u-joints they are trash. Go with spicer forged at the minimum. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  10. Orange Crush
    Mar 6, 2003
    440
    With the drive flanges you'll be spinning the front end all the time. /forums/images/graemlins/thumb.gif
