Warn 8074
Discussion in 'The Garage' started by 71 Blazer, Apr 25, 2006.
  1. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    I have a Warn 8074 on my truck and after a little use it will stop pulling. The seliniods will click like they are making contact only it won't pull, if I revears it it will work but I have to let it sit for a while, to cool off I guess. Is the motor toast? Also seems to struggle when it does work.
  2. 71 Blazer
    Jul 16, 2005
    184
    windsor virginia
    Common people, don't make me go to Pirate with this question. Cause I will do it.
  3. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    I have a buddy that has the same exact winch with the same exact problem. The guy at the 4x4 shop told him that he needs a new motor. I cant remember what they quoted him for a new motor.
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    My 8274 does it randomly with a brand new motor. I think the solenoids need to be opened & cleaned
  5. 71 Blazer
    Jul 16, 2005
    184
    windsor virginia
    How much was a brand new motor? Should I invest money into this winch, or buy a new one?
  6. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    A guy that used to work for me said he replaced the motor on his with a ford starter motor. Said it is an exact match. This would probably be easier to find in a junkyard or maybe cheaper.
  7. ak bandit
    Sep 10, 2004
    386
    Eagle River, Alaska
    I think the motor my buddy was looking at cost $245 new. He said he'll probably just sell this winch and get a new one.
  8. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
  9. 71 Blazer
    Jul 16, 2005
    184
    windsor virginia
    I like that ford starter thing better, what model and engine size ford?
  10. 71 Blazer
    Jul 16, 2005
    184
    windsor virginia
    How long can you use your winch, mine will start acting up after 10 mins or so. The motor gets pretty warm, not sure how warm it should get. It is all sealed so I could see why it would get warm. Maybe its normal in the older winches. Can anyone thats been arould for a while that can verify this?
  11. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Warm, even hot is normal. Its just an electric motor w/o any real cooling. I forget what the 8074 can't do, is it no free spool or no power out? If its just no free spool I'd fix it. And if you have good connections and the solenoids are working its most likely the motor. A starter shop or e-bay can get you back to winching.
  12. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    I've never run it very long or hard under load. The one time I did really need it for a long hard pull, I was burried so deep in snow (You couldn't even see the top of my 38.5" tire) the winch just stalled out. It didn't have the cahones to move my 6000lb truck and 1000000lbs of snow.
    Thats there rcurrier44 telling me I'm fscked :D
    Mike
  13. 71 Blazer
    Jul 16, 2005
    184
    windsor virginia
    What about upgrading the motor size? If it had a little large motor it would have to work less to pull the same, right? Or would I just be putting myself in a better position to brake it? If have to replace something I would like to use this oppertunity to upgrade.
  14. KingDuramax
    KingDuramax 1/2 ton status
    Jan 17, 2006
    451
    NY 14701
