warn 8274 on a stock front bumper?
Discussion in 'The Garage' started by 85 Jimmy, Dec 14, 2006.
  1. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    has anyone rigged up something to put a 8274 on the front of there bumper??? i'm going to get myself one as a christmas get to myself but can't afford a nice winch bumper right now. i'm not scared to hack away at the stock bumper. if anyone has done this and has pics i'd appreciate it
  2. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    It's not possible you should send the 8274 to me for Christmas.:D
  3. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    I built a cradle to mount mine on the front of my dually. It mounts to the four center bumper bolts.
    Russ
  4. Big Blzn
    Big Blzn 1/2 ton status GMOTM Winner
    Jan 30, 2006
    3,587
    Orange County, CA.
    Russ. nice setup with that winch. what is that clevis that is sticking out of your license plate connected to. I have a 72 K5 and want to keep my stock bumper where I have a "hidden hitch" type thing going on and wouldn't show behind a hinged license plate frame. I need a strong tow point to connect a strap to. COuld you take pictures of underneith and behind the bumper and post them to show whats happening back there?
  5. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I used a winch mount that was on my friends CJ7 and removed the bumper. It fits perfectly between the frame suprisingly. I have 52's up front so the front bumper wasn't a choice for me....
  6. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    both setups look great, but since it's my dd i think i'm going to do something more like the first setup
  7. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
  8. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Here is a couple of pictures right after I built it. That is just a 2" receiver that I welded to the bottom of it. It comes in real handy for moving my trailer around as I can drive it forward.
    I use my truck primarily as a work/farm truck so did not try and tuck the mount up tight. This would probably stick out to far for someone who was wanting to do a lot of 4wheeling.
    Russ
  9. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    You could always mount it behind the bumper.
    Altho I had to do a lot of work to make room for it. :eek1:
  10. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    that's pretty sweet looking. I thought I did good when I tucked mine in, but apparentally you moved the rad back and put in electric fans?
  11. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    Who needs a radiator? Just drive faster. :D
    PS radiator is mounted in the back/bed behind the cab. :wink1:
  12. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    i think this is the setup i'm going to have to go with so i can use the winch on the front or the rear!
    when you got the winch did it have the craddle it's sitting in or did you build that also?
  13. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    It's called a Multi-mount at Warn. It comes ready to slide into a 2 inch receiver, or you can make your own mount. http://warn.iwebcat.com/_Members/lookups/partdetail.asp
