Warn 8274 winch failing me?
Discussion in 'The Garage' started by Thumper, May 17, 2003.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    My 8274 let me down yet again today. They say they are a super winch, but this one is pathetic. As soon as it starts to really get loaded down, it stalls out and draws big time from the battery. I cant winch my self out of anything anymore. It seems to be getting steadily worse. What would be a good part of it to start checking out? The motor? The relay pack? The gear set? I am suspecting the motor but wanted to ask the pros! /forums/images/graemlins/smile.gif
    Guess I better check out Warn website and price out some stuff.
    Later
    Mike
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you might also want to get a good snatchblock /forums/images/graemlins/shocked.gif /forums/images/graemlins/thumb.gif
  3. Thumper
    1,582
    Alberta Canada
    Actually, I have tried a snatch block. The winch even stalls out with it before it hardly moves me. Thats why I suspect the motor. But need a starting point.
    Mike
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i cant say for sure but i would look at the motor as well
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i say you need a slightly larger hammer for persuasion...
  6. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    The last time I used my 8274 on my Orange Blazer, it was acting similar to what you described. I had to pull out two trucks, and on the 2nd truck, it acted like it wasnt even pulling. It would pull for about 3 seconds, then bog down and draw a bunch of juice. If I let it sit for about 30 seconds, I could get another 3 seconds of pulling, and so on...
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    did you get it fixed? what was the problem with it?
  8. mountainexplorer
    Nov 14, 2001
    4,903
    Havent used it or touched it since. Been to busy to mess with it.
    I was kind of wondering what was wrong with it myself. Tired, worn out motor? It didnt seem like it was overheated or too hot at the time. It was working great the day before. Used it to pull out 4 rigs in 2 days.
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If your bat and alt are good, its the motor. Check the charging system if you haven't already.
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
