Warn 8274 winch question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, Jan 6, 2003.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I just bought an older used Warn 8274(8000 lbs.) winch and the only problem with it is that the control box that goes on the cable coming out of the winch is missing. There are 3 cables coming out of it(black, white and green) and when I put them together the winch will pull but I am not sure how they go together. Also, why is there 3 cables, does this type winch have 2 speeds? I pulled another blazer with it so it pulls strong enough only I am not really sure about how to connect the new switch correctly. Please help! Also, if anybody knows this type of winch please let me know how it compares to other winches. /forums/images/graemlins/ears.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    that winch kicks butt. You can buy those control units. There are three post as one is power. The power is routed to forward or reverse. So three total. Hope this helps.
  3. bajaviking
    Apr 10, 2002
    752
    Baja
    Thanks, this is my first winch so any tips on how to maintain and service these things would be appreciated. /forums/images/graemlins/thumb.gif
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Hit Warns web site. They have all kinds of info there that should help you out. /forums/images/graemlins/grin.gif
  5. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    If you service it. Drain oil by spliting upper & lower case halves. When I did mine the first time 8 years ago, it had reminence of oil thick goo about 2 oz. This was a well used 8274. According to the build code it is a 1977 model. I cleaned it out refilled w/ non detergent 10w30 6 oz. as per Warn reccomendations. Grease the plastic cap at end of drum. Clean all electric connections. Hope this helps Ed. It is still PULLING STRONG 25 years later /forums/images/graemlins/thumb.gif
  6. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I have the same winch /forums/images/graemlins/thumb.gif
    but I want to sell it to put money twards the drive train /forums/images/graemlins/frown.gif
    and yes i kicks but too /forums/images/graemlins/grin.gif
