Warn Full float kit for 10 bolt
Discussion in 'The Garage' started by 91GMCSuburban, Apr 5, 2004.
  1. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Yes. Don't let the 14FF Drink the Kool-Aid crowd tell ya any different. That's a very good kit and in fact, a former member here used that kit on a 12 bolt and he didn't have any problems with it.
  3. mogas
    mogas 1/2 ton status
    Apr 5, 2004
    118
    Flagstaff, AZ
    There's no doubt that it would be stronger than a stock 10 bolt, but, I don't think it would be in the same ballpark as the 14 bolt. IMO
  4. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Seems like for the price of that Warn kit you could buy 3 or 4 14 bolts.......
  5. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    Many will probably argue that a 14FF can be bought and set up for that price. I got mine for free. It was "taking up too much room in my buddies garage. /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  6. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    Sure, (plus wheels, gears, lockers, 6-8 lug conversion for front, etc)
    Again, for the total package of this kit compared to a total package for a 14bff upgrade, is this worth it?
    I also like the idea of keeping the pumpkin small for clearance purposes, but... (and no, I don't feel like boring out my carrier to allow them to use 14 bolt axles).
  7. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I have that set-up on my 88 k5. Works great for me. I too do not belive that the universal answer to any 10 blt question is " Drop in a 14 bolt ". I pull my boat, drive to work every day, and have put on well over 10,000 miles on it and it was used when I got it from another board member who wheeled it with no problems as far as I know. I would like to go 14-60 but tires & wheels and freshen up the axles and bla bla bla more money more money.... Unless you beat the livin piss outa your stuff, a 10blt with an after market differential and after market axles will outlive the rest of the truck. /forums/images/graemlins/wink.gif
  8. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    If your worried about the c-clips then moser sells c-clip eiminator kits that you can buy at summit for around 140 bucks. I think what i'm going to do with my 12 bolt is put a c-clip eliminator kit in it and buy a set of the superior shafts that ord sells, seems like a much better option and will cost less than a 14 bolt especially since i'll only be running 35" tires.
    C-Clip eliminators: $140
    2 superior axle shafts 12 bolt 30 spline shafts: $202
    Total: $342, thats a lot less than I would pay for a 14 bolt after freshening it up and new wheels and stuff.
  9. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    Then why mess with the ff kit? I don't have it on my burban. Until my scout is done that is all I have to wheel. The only problem I'vee ever had with the rear was grenading the spider gears. The front short side is what I hate. I'm always blowing that shaft. But like you I am not rich and won't buy expensive upgrades. Especially when they are not guaranteed to eliminate the problem.
  10. JIM88K5
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I made no mention of C clips nor does the 10blt ff use them.
  11. JIM88K5
    Apr 27, 2001
    1,384
    Vancouver, Wa
    What are you talking about ? Man if I had your money I'd burn mine /forums/images/graemlins/wink.gif. Rich ? I bought two hot rodded 10 bolts for less than the sum of the total parts to build said axles.
  12. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    Good kit yes. Pricey, Yes also.
    This upgrade probably puts your failure point at the ring and pinion instead of the axle shaft. The 8.5 is not exactly a weak ring and pinion. Reading your sig, your only running 33's. If this is as big as it going to get then the kit's a good solution. The 14bff is very strong but most of them you buy for cheap should have new bearing/races/seals put in adding another $100 or two. I believe you can get wheel adapters from 8-lug to 6 lug for around 100, just another option. Doing the wheel spacers would also even out the front/rear track width.
    If at some time you plan on going with more then a 35inch tire. I would say bite the bullet and go with a 3/4ton swap.
    Mike
  13. JIM88K5
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I agree..
  14. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Seems kind of an expensive 10 bolt there. I'm a proponent of 10 bolts in the right application... but that's a lot of money. I'd convert to rear disc, buy some 4340 shafts, and buy a locker for that.
  15. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    I do plan on staying with 33" tires because I will tow as well as wheel. And because I am going to tow and I have a detroit at the rear, the option to go to a FF and lockouts is kind of intriguing (seeing as how I was told not to tow with a locker). This kit also has rear disc application.
  16. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    How are the lockouts going to help you tow? Are you flat towing the truck or are you using it as a tow vehicle?
  17. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    As a tow vehicle. So I guess I misunderstood or someone was pulling my chain.
  18. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    I'm not sure what they told you but I can't think of a reason to have lock out hubs on the rear of a tow vehicle. I guess you could unlock one hub to take some stress off the locker while engaging and disengaging, but it would put a lot more stress on the other shaft and the locker in general.
    A stock 10b with stronger aftermarket axle shafts and a disk brake kit seems like a pretty good option. Just carry a spare shaft -- if one breaks, the disk won't let it out if you stop soon. For $600 you can buy 5+ new spare shafts. /forums/images/graemlins/grin.gif
  19. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    For what you'd spend on a Detroit for the rear you might as well spend the extra $80 and buy an ARB. Then towing won't be an issue.
  20. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    Who has a rear disc break option for 10 bolt?
    Axle recommendations?
