WARN full floating kit.
Discussion in 'OffRoad Design' started by KENT, Jun 14, 2001.
  1. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    Is this a bolt on kit or does it require welding?
    How much of the existing spindle is cut off on a 12 bolt.
    Thanks.
    Kent
    1989 K5
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    I have only done a few, no weilding !
    About 1/2 inch.
    Good luck
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    No welding, cutting is about a half inch. Sound like a broken record?:-)
    The cutting could be done with a hacksaw if you had enough beans to run it that long, but a hand held bandsaw or a sawsall works better. It doesn't have to be really precise, and can be cleaned up with a grinder. You will also need a couple of clamps and a 7/16 drill bit and motor to drill the holes larger.
    Making the world better, one truck at a time.
    [image]http://coloradok5.com/logo_ordsmall.gif[/image]
    SW-ORD
  4. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    How much for the kit. Are you stocking them?
    The axles in my 12 bolt are questionable and I need to do something soon.
    Also can you run disk brakes with the kit?
    Kent
    1989 K5
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Hey Kent, did you get the 12 bolt in your truck? Hope it was allright...........saw the comment about the axles, what is wrong with them?
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.alloffroad.com>http://www.blazzinor.alloffroad.com</A>
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    If they aren't in stock, we usually have them within 3-4 days. Cost is $805.
    You can run discs with it, just like a plain old 12 bolt. Warn has the brackets, or you can use a standard 12 bolt kit.
    SW-ORD
  7. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    Back bearing on the driver side had a repair bearing in it. I want to get back to stock bearings and either need to order replacement axles. Was wondering about the ff kit.
    Got the front rebuilt and installed. Waiting on the shocks and brake lines to finsih the front. Passenger side hub was shot. Wound up having to replace that.
    Kent
    1989 K5
