warn hs9500
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by jasonkh2tg, May 20, 2003.
  1. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    I will be mounting my warn hs 9500 winch this weekend and installing my transfer case, NP 205 with a twin stick..I can't wait I'll show the pic's of the twin stick this weekend if I get around to it...also I may bleed the brakes if I get around to it I will be using russel's speed
    bleeders...who out there has used speed bleeders before...also I have a 2" inch body lift so I may have to make the cluch rod longer (anyone done that with any luck..)
    any tips would be great...
    opps I just made one post like 3 questions...
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I've got the speed bleeders on my s-10 (on the Blazer I just have stock ones caked with mud). They work good. Just put a line on one, crack it open a 1/4 turn, and pump the brake a few times. I am working on building a vacume bleeder to make bleeding the blazer easier.
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I extended my cluch rod.
    What I did was take the rod out and cut it in half.
    Then figured out how long it needed to 'grow'.
    Next took a heavy gage pice of steel pipe that just fit over the rod. Welded the pipe to each pice of rod(had a good 4" of rod inside the pipe on both ends to make sure it was nice and strong) and wala a longer rod with stock ends. Painted it and tossed it in. Been working great ever sence....
    Good Luck
  4. jasonkh2tg
    Mar 27, 2003
    139
    MPLS MN
    Yea, I like the pipe Idea you did...I was thinking at first of using solid rod stock but the week points would be at the welds...so yea I'll go with the pipe idea and make sure I got plenty of overlap...that way the welds are there just to hold the overlap pipe in place,and not for strength for pushing in the clutch....thanks... /forums/images/graemlins/wink.gif
  5. Burt4x4
    6,854
    Ya exactly! You got it!
    Like I said it worked out great and never had any issues with it /forums/images/graemlins/thumb.gif
