Warn hub install
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Panther, Mar 8, 2002.
  1. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    Hey everybody. I am in the middle of my warn hub swap and have a general question.
    Everything in there is pretty greased up (well it's more pudding-like from muddin, but that's another story). I am planning on wiping it out real well to get the old, dirty grease out. With the Warn hubs, should I make sure to grease it up real well when I put it back together or was that excess an auto hub thing?
    And if so, is there any special grease I should use?
    Thanks.
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Don't grease it too much. If you do, the gears won't be able to move properly. I usually clean mine off and simply spray them with a spray lubricant.
  3. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    What Tx said. I just put a thin film of grease on there. Too much, and your hubs won't lock when needed, or unlock. Hi-Temp trailer bearing type grease is what I use.
    Boss
  4. Blazer83
    Blazer83 Registered Member
    Aug 31, 2001
    26
    Houston, Texas
    Marine Grease won't break down as quick if you do a lot of muddin'
  5. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    While marine grease is good to prevent break down when wet, it can mask other problems. Warn hubs (especially premiums) should be disassembled and cleaned after tromping through deep water and/or gritty mud. While they have a nice rubber seal, if water gets inside, the gears can rust. They are all metal. Sure, Warn will replace them if they do, but you don't want to find out they rusted stuck when you need them most.
    And, grit from mud is VERY damaging to bearings and gears. It is just a good idea to maintenance these after such romps.
