Warn Hub Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin84, Sep 25, 2000.
  1. Blazin84
    Blazin84 Newbie
    Sep 25, 2000
    AZ
    Hello All! I just recently installed new Warn premium hubs for my '84 K5. I have noticed some oil/grease around the locking unit. Is this just a bad seal on the hubs, or is this a sign of something worse? 4wd does feel a little stiff when engaged.
    Chris
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Did you "grease" your hubs when you installed them? You shouldn't use Grease when lubing them, you should use motor oil as per the instructions!
    If you used the motor oil then maybe did you put a lot of grease on the bearings and in the bearings when you packed the wheel bearings?
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
