warn hub swap
Discussion in 'The Garage' started by AJBK588, Jan 13, 2007.
  1. AJBK588
    AJBK588 Registered Member
    May 19, 2005
    12
    IL
    i was wondering if i put some warn premium hubs in my k5 10 bolt will i need to do any thing else and is there anything i should know before going at it. I currently have stock auto looking hubs will the warns go right in?
    thanks aj
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Direct replacement. Nothing else needed to be done.
  3. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Easy swap and WELL worth it.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    While you are in there check and lube the wheel bearings.
  5. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    I believe it is just a simple swap (though I've never done it) Where ya at in IL?
    EDIT: Damn while I typed that three people replyed, man im slow!
  6. AJBK588
    May 19, 2005
    12
    IL
    can i take them out as easy as the stock ones and does the main keeper ring come out the same as stock?
  7. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Yes, and Yes
  8. AJBK588
    May 19, 2005
    12
    IL
    im from tinley near oak forest
  9. 85mudr
    85mudr Registered Member
    Dec 15, 2006
    17
    New Whiteland, Indiana
    Just did the swap when you get the old hub body off theres a snap ring and washer, I could not figure out if that stayed or went. It holds the wheel nut on ( I Think ) anybody know?? Just trying to help Ajbk588 and myself can send pictures if you need help with the swap.
  10. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
