Warn/hubs-89 Surb
Discussion in 'The Garage' started by ARTIC, Jan 11, 2005.
  1. ARTIC
    ARTIC Registered Member
    Dec 15, 2004
    12
    B.C. CANADA
    THANKS for getting back to me so fast,the short axle only moves about a 1\16",but the long one moves about 3\16",i gues i should pull the WARN -free/lock-hubs off and take a look in there to see whats cookin.do you just need and allen key and that it?it kinda looks that way?what in side,lots of little parts that fall out and its a puzzl?or its not that bad realy.allso how do you tell if you have DANA running gear on your truck,somone spent a lot money on this truck befor i got it,it had a work order in the glove box forover $2,800 -brakes,exhost,rear/dif,tires.it could be somone botched## the job on the rear end,get this,iam runnen 32"x11 with a 700R4 locker,the spedo in to the trany is stock,no step gear,and my dash speedo saya iam doin 10 over the limmit,60 is realy 50-that doesn't make sence,bigger tires means your speedo is under not over rite?some more info no this would be apreatiched,THANKS
  2. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Who are you talking to?
  3. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    i assume he ment me cause i replied to his post earlier
