warn hubs question???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mxrcr589, Oct 21, 2003.
  1. mxrcr589
    mxrcr589 1/2 ton status
    Apr 17, 2003
    148
    poop
    i just got some warn hubs and when i was putting them in, i couldnt get them to fit all the way without taking the washer and circle clip in front of the lock nut, im not sure if anyone can understand what im trying to say but it seen that the washer and cirle clip should stay in to keep that lock nut from coming lose. by the way i have a 1990 , its a 10bolt, any info would help thanks
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Did you remove the snap ring behind the old hubs? Kinda gotta look real close. Yeah you need that ring with all the holes in it between the locknuts. If it is just a snap ring that goes in the groove on the shaft I have been told that you don't need that. I don't have them and everything works fine.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I haven't had that snap ring for over 3 years now, no issues with that one.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Sometimes you need to take a big screwdriver or prybar and stick it in the axle joint and force the axleshaft out a little bit to get the hub in all the way and the snaprings one. I have had to do this before. Sometime you have to sometimes you don't. If it is just a little clearence that you need then that should work.
    Harley
