warn hubs WTF
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Aug 2, 2002.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Ok just got the front all back together (put new brakes and wheel bearings) and now one side wont turn to lock the hubs...Now when I took it apart one side was put in by the P.O. different then the other so how and what is the order of the hub set up...BTW it is a d44..Dose the first spring that is closer to the inside go behind the gear that is held in with that screw or in front of...mike
    Thanks /forums/images/icons/smile.gif /forums/images/icons/smile.gif /forums/images/icons/smile.gif /forums/images/icons/smile.gif /forums/images/icons/smile.gif /forums/images/icons/smile.gif
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    behind
  3. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Ok new ???? the hub fuse that goes in the hub has the gears on one side of the hub fuse and none on the other hald of the gear....which way does it go with the teeth towards the inside or out side....mike
