Warn Premium hub install question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Aug 23, 2001.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I went to replace my auto hubs tonight with Warn Premium manuals. First of all the install was a cinch. Took 5 minutes per side (okay, maybe 10). Of course, they stay in much better when you use the locking rings in the bottom of the box, but that's another story.
    My question is that after the install, I went to turn the lock dial. When going from Free to Lock, it is very difficult to turn after it is about 2/3 of the way locked. And it doesn't snap when it goes into Lock like it does when going into Free. Is this okay? Or did I do something wrong?
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    Who put a stop payment on my reality check?!?
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i dont think he will be on the board tonite but you can pm the general. he did the same thing on a converted 10 bolt.
    Cause Stone Cold said so !!
  3. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    One question. Did you happen to grease the hub? If you used to much it won't allow proper movement in the hub to engage and disengage. I usually use a very light coating of grease...very little.
    Ric
    <font color=red>"Wheel hard or go home."</font color=red>
    click to see <a target="_blank" href=http://www.off-road.ws/images/users/BOWTIE/bowtie5.jpg> BOWTIE</a>
  4. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Take her apart, clean out hub housing with brake cleaner, check pressure spring, grease, and reinstall. If that doesn't get it, take back out, keep assembly in hand, apply pressure to spring, and then turn, if she locks than something is wrong in hub, if not, something might be wrong with locking hub. I had no problems with any Warn hubs ever, so a little unfamiliar territory.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  5. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    exact thing happen to me so what i did was grease it up a little and spray WD-40 on the hub and moved it to the lock and free position over and over till the hub itself got soft. also the reason you dont hear it pop in is cuz sometimes the teeth on the shaft and the teeth on the hub dont line up, thats no big deal as soon as the tire turns or axle shaft it will lock it for you. hope i helped
    <font color=purple>I put the Panic in Hispanic</font color=purple>[​IMG]
    <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You probably didn't remove all the necessary snap rings and such. Just take the old stuff out completely, all snap rings, etc., just gut the old stuff out and put in the hub, big snap ring (bend the ends for easy removal) and the cover.
    Tim
  7. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Yup, either you still have some of the old stuff in there or you need to grease it a bit and work it back and forth until it loosens up .........and the reply that says it has to seat properly is right too, but it will when you start to drive it . You'll never regret putting those on by the way !
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> BOW CHICKA BOW WOW !
