Warn Premium Hub PN#20990 on Factory 10 Bolt
Discussion in 'The Garage' started by irelands18, Dec 2, 2005.
  1. irelands18
    irelands18 Newbie
    Sep 20, 2004
    3
    South Euclid, Ohio
    I installed a set of Warn premium manual locking hubs on my 87 K5, with a factory 10 Bolt ( Now I know before you all jump all over me, I'm swapping in a Dana in the spring) but for now.... They wont lock into the axle, and from reading some forums I am sort of under the impression they wont work. Is this true??? If they will work, any Ideas as to why they wont lock in???? The dial rotates all the way as if they are!
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    How do you know it's the hubs fault? No reason they shouldn't operate correctly, pretty idiot proof on the install...
    I have a front 10 bolt...
  3. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    sounds like you left a part in that should have been removed. I have the same hubs on my 89, no problems.
  4. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    I've got the Warn Premiums on my 10B, they work great.
  5. irelands18
    irelands18 Newbie
    Sep 20, 2004
    3
    South Euclid, Ohio
    I removed the entire automatic hub assembly, an installed them according to the instructions that came with them!
  6. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Same here, 1985, slick as snot.
  7. dewster
    dewster Registered Member
    Jul 21, 2003
    31
    corona ca >> austin,tx
    mine worked good
    are you sure you didn't forget to remove something? bad spline on something?
  8. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Tranny in N, hubs first, then T-case?
  9. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Some auto hubs have a dual stub snap ring set up. Might check that.
  10. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
    I seem to remember there's a washer/spacer behind the hub that slips over the axle shaft and upto the spindle that needs to be removed.
  11. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
    or when you install the warn hubs you don't need to use the snap ring. I think it's a case by case basis.
  12. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    I had a problem... I had autos then i switched to warn hubs. I got the autos totally removed and when you looked in there you could see a clip on the stub shaft, a washer, then the huge nut. After fighting with it, all I had to do was remove the washer, put the clip back on, put the inner hub on, then the cap and i was set. Maybe thats what your problem is?
