Warn Premium Hubs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cegusman, Nov 27, 2001.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Will the warn premium hubs for a 1/2t 10 bolt fit a 3/4t dana 44
    Houston, TX
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Yes they should fit....
    &lt;&gt;&lt;<a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>&gt;&lt;&gt;
    Suck Fumes Ford Boy
    I keep trying to lose weight, but it always finds me!
  3. not4show
    not4show 1/2 ton status
    Apr 24, 2001
    280
    Alabama
    Is the Dana 44 an internal or external locking hub type?
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Don't know, what is the difference? I may posibly be buying it, have not seen it yet. I blew my spider gears in my 10 bolt 2 days ago, 3 days after buying some warn premium hubs.
    Houston, TX
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You do realize that the dana 44 is 8 lug right? If you dont have a 14 FF or 8 lug 14 SF then you will have to either carry two spares or change rear axles. You can always just put new spider gears in your axle. You can get them from GM or a junkyard. The dana 44 and 10 are the samt strength because they use the same small u-joint.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  6. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I may be getting a 14 bolt ff too, I called chevy today and they said thay dont just sell the spider gears they want to sell me a new carrier. Does anyone have a part number? I would be alot less work and cheaper.
    Houston, TX
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The internal hubs are the same 1/2 and 3/4. Some trucks came w/ external that are not the same.
    As for GM not having the spider gears you still have a few options:
    1) Buy some off of someone here
    2) Buy some from a wrecking yard
    3) Install a front Lock-Right locker (which I would not sugest doing because you will break even more parts)
    4) Don't use 4WD (BORING!)
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  8. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I don't think the locker necessarily makes you break more parts. It depends on how you wheel. An open diff can be the worst because a wheel gets to spinning, and then when it suddenly grabs....POW!
    I recommend the Lock Right.
  9. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
  10. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Right.
    <a target="_blank" href=http://www.gowarn.com/hub_chevy.htm>Warn Premium Hubs</a>
    Part number for the 69-91 Blazer is 20990
    Part number for 1/2 ton 69-87 pickup is 20990
    Part number for the 3/4 ton 77-87 pickup is 20990
    Those are the exact same parts numbers. If they don't fit why would they have the exact same parts numbers stating they do fit?
    Suck Fumes Ford Boy
  11. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    That is how I blew my spider gears last week.
    Houston, TX
  12. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I try to not have any wheel spin (unless in mud) mainly because I don't want to have to buy another set of tires any time soon. That makes for some tough driving w/ 2 open diffs.
