warn premiums
Discussion in 'The Garage' started by rooferbret, Apr 18, 2004.
  1. rooferbret
    rooferbret 1/2 ton status
    Dec 26, 2003
    265
    Sacramento,CA
    Just picked up a set for my 10 bolts and would like to know how to install them. Simple unbolt the old and install? Any issues? Thanks, Bret.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Pretty much unbolt the old and install the new /forums/images/graemlins/thumb.gif
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It isn't hard but it is a little harder then unbolt bolt.
    You can remove the caps from your old hubs by removing the 6 bolts on the hub. The cap comes off. Then you need to take off 2 snaprings to get the hub body out. One is right on the end of the axleshaft. A set of snapring pliers makes that a breeze. You can use a screwdriver to seperate it too I imagine.
    The second snapring is hard to see. It is a large ring that snaps into a groove in the bearing hub walls. You may have to look and feel for it a little and then find the ends. You can use small screwdrivers to get it out but a dental style pick works wonders on this.
    Once both snaprings are out the inner hub body should come out. You can screw a bolt from the hub into a hole to pull it out with.
    If you are replacing auto hubs there will be another snapring behind the hub body you will have to remove. It is on the axleshaft like the first small one.
    Harley
  4. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
    Will my snap ring pliers fit down inside to get the second ring out? seem realy simple! Thanks for the insite! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Mine did with no problems. It is not that far down the bore only like 3" or so. That is only on trucks that have auto hubs on them too. It won't be there with manual locking hubs.
    Harley
  6. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
    /forums/images/graemlins/thumb.gifthanks
  7. 78GMC1/2TON4x4
    78GMC1/2TON4x4 1/2 ton status
    Mar 10, 2003
    167
    Mount.Angel, OR
    HAVE FUN! /forums/images/graemlins/truck.gif
  8. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    bret... you didnt tell me you actually wanted directions.... heck bring that bad boy up here and Ill put them on for you... /forums/images/graemlins/waytogo.gif
    cam
  9. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
    Ok, What am i missing. I pulled the covers on the warns and cannot find a snap ring. How do i remove this? BFH and skrewdriver? /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/1zhelp.gif
  10. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
    Ok, What am i missing? I removed the cover on the warns and cannot see a snap-ring. How do i remove this? BFH and skrewdriver? /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/1zhelp.gif
  11. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    are you looking for the large snap ring? if so it may be covered in grease, it looks like a large wire ring and is located on the outer hub and it located in a notch. I use a dental pick to find the end.
  12. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
    The only snap-ring i can find is the non removable one at the axle
  13. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    are you attempting to remove some old hubs out of a 10 bolt?
  14. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
    Removing the warns from my just aquired axles to install in my existing. Just found the snap-wire and finally got one out. Are stock ones this fun or do they have a real snap-ring? /forums/images/graemlins/ears.gif
  15. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    its been so long since Ive seen stock hubs I dont remember. The wire snap ring is simple once you know what to look for though! Glad you got it out /forums/images/graemlins/thumb.gif
  16. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Do yourself a favor and buy a set of picks. The make getting the large wire snapring out easy. It takes me longer to the the small snapring out then the large one with the pick. You just hook the ring and pull with the pick. Makes life nice.
    Harley
  17. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
    Yep Harbor freight. Got a set of picks and It really made it simple.
    Thanks for the help!
    Bret.
  18. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    Bret.
    [/ QUOTE ]you got a part # for that
  19. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    A part number for the picks?
    Just go to ANY store that sells tools.
    Not a specialty item.
  20. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
