Warn vs. Ramsey vs. Mile Marker
Discussion in 'The Garage' started by 89GMCSuburban, Nov 21, 2002.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Warn M12000----------$1,139
    Warn M15000----------$1,299
    Ramsey Patriot 15000 $1,095
    Ramsey RE 12000------$1,095
    MM Hydraulic 12000---$899
    Which one would be best for my behemoth?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    well if it was between these 2 for the $160 price differance id go with the M1500 you get an extra 3000 pounds for $160 /forums/images/graemlins/smile.gif
  3. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    i would go with the ramsey you cant beat a worm gear drive winch for power and the reliability. just ask anybody in the towing business.
  4. hardcore71
    hardcore71 Registered Member
    Nov 21, 2002
    86
    Weare NH
    the most important note i can make between the warn 12k and 15k is the 15k has only 90' of cable where the 12k has 125'. this is what made the difference for me. also i was all gung ho for the mile marker hydrallic winches until my starter crapped out and i had to winch out with the engine off. impossible with a hydrallic. just for info i am moving from an 8k ramsey to a 12k warn. my $.02
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    No question - Hydraulic. /forums/images/graemlins/thumb.gif
    You can run the thing all day long and it won't overheat. Would be better to run a dedicated pump though...
  6. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    I want to go hydraulic. that 1 time you stall somebody else can pull you out
  7. Mikeyg79
    Mikeyg79 Registered Member
    Aug 3, 2002
    83
    I'd go with a hydraulic. Run em all day (there must be a reason comercial outfits run hydraulic stuff.)
    Got plenty of space under the hood for a pump for a snow plow pump...
    Mikey
  8. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    The lack of cabel on the 15k is a real big drawback in my mind.
    Ken H.
  9. Rasberry
    Rasberry 1/2 ton status
    Mar 30, 2001
    205
    Orlando, Fl
    I wouldn't go hydraulic, cause that one time you stall out and you don't have someone to pull you out your gonna kick yourself. Yes hydraulics can run all day, but how much of the day do you really think you'll use it. I have a warn 9000i and did 4 pull within minutes of each other and never showed signs of slowwing down.
  10. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    I would say it depends on what your going to use it for. If its for serious 4 wheeling, the WARN hands down. THe 12 K sounds like it would be better, the cable length of 90 foot on the 15,000 really sucks. If you do some serious shopping around, you can probably get the Warn's a little cheaper. Take a look on this site and on Pirate4x4 and see whats on the front of most rigs. There ar WARN winches there for a reason. Hydrolic is great as long as you dont mine the slow line speed, or the fact that your engine has to be running to use it. Then add in that the hydrolic winch while in use makes it about impossible to steer the truck and winch as well (at least the ones that are driven off of the power steering pump, even with the so called valve to fix this problem).
    Depdog
  11. Depdog
    1,657
    Georgia
    Call Mike at Bent and Twisted for a price, tell em you saw the add on Pirate 4x4
    530-342-3003
    Depdog
  12. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Cool, thanks guys! God, I love this board... One thing, I've seen a lot of burbs use the Warn 8000 lb winch, do they use it because of it's super-reliability or what?
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    no reliability difference in the old style WARN winch.
    just Jeeper propaganda.
    if it were a better design dont you think Warn would incorporate it in the entire line of winches?
    or someone would jump on the bandwagon and duplicate it?
    fact is spur gears are the worst style in winch applications.
    I agree with the above post recommending worm drive winches, no need for external braking as it is a design feature that the drum cannot turn the worm
    planetary gears are more effecient at tranfering power but still require a brake be added to hold the drum from turning.
    this leaves Ramsey as the only choice left on your list last I looked
    I would look to the Pierce Sales cheapo ones and go real hydraulic rather then the steering pump MM kits, seperate issue.
    hydraulic KILLS electric in everything other then running with a dead engine.
