Warn winch intergrated Solenoid
Discussion in 'The Garage' started by k5blazerus, Apr 21, 2003.
  1. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Has anyone had to replace any intergrated solinoids in there warn winch. What is the price on each solinoid?
    I have 2 that are bad. The 2 that are bad are the ones that run the motor to bring in the winch Line.
    Anyone have this problem before?
    Colin
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Warn winch intergrated Solinoid
    If i remember correctly, the solenoids in the packs are standard ford starter solenoids. You can pick those up for cheap new.
  3. k5blazerus
    Apr 22, 2001
    654
    Bend, OR
    I contacted Warn and they said do not use a ford starter solenoids. I am confused. The solenoinds in the winch have ford part # on them.
    Colin
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Did they give you a reason why?
  5. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    To buy them from a 4x4 shop they will run near $20, but if you run the Ford ones the tend to get to hot fast and burn out faster. If you have some one with you that has a winch all the time it would be ok to run the Ford ones but know that when you REALY nead it, it might fail. The winch a got 2nd hand had some Ford Solenoid in it and they have all gone bad but one. As they when i put Warns back in. you can try the Fords, but you might want 1 or 2 spare ones.
    Again the Fords Will work, but they could burn out faster.
