Warn Winch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sammy, May 21, 2001.
  1. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    Found an old rusty Warn 9000. It used to be on a boat trailer. It is a few simbolic bugs cheap. I know already that it needs a new cable, maybe I need to open up the motor to service it. Now, is this a deal or should i leave it?
    "K5 Grand GT Blazer Silverado in the Netherlands."
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have the warn xd9000i and i love mine if you can get it cheep i would say go for it[​IMG]
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have an HS9500i an it has been great! I hear alot of good stories about Wans service especially with older winches!! The only thing you may want to watch is if it was used around salt water alot. The salt could have done some corroding.. I would open it up.
    [​IMG]GO PENS!!!!!!!!!!
  4. Sammy
    Dec 8, 2000
    250
    Oh, did I mention it is a 24volt version. Is that better?
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Hmmm... To run that with a 12 volt system would require a lot of work... Hmmm..
  6. Sammy
    Dec 8, 2000
    250
    No problem. A solonoid and an extra battery will put it on 24Volts. That is not a problem. But is the 24Volt version faster or anything?
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, I wasn't thinking of that... I dont htink the 24v is any faster.... I think it is just made to work with the 24volt systems.
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    Here is data from Warn fo rtheir M12000 winch:
    12V DC PERFORMANCE SPECS:
    Line Speed
    Ft./min.(M/min.)
    30(9.14)
    14(4.27)
    8.62(2.63)
    6.92(2.11)
    5.80(1.77)
    4.39(1.34)
    3.86(1.18)
    Motor
    Current
    67 amps
    140 amps
    210 amps
    250 amps
    320 amps
    370 amps
    440 amps
    24V DC PERFORMANCE SPECS:
    Line Speed
    Ft./min.(M/min.)
    31.4(9.57)
    11.7(3.57)
    9.5(2.90)
    8.5(2.59)
    7.5(2.29)
    6.5(1.98)
    6.0(1.83)
    Motor
    Current
    24 amps
    105 amps
    129 amps
    152 amps
    175 amps
    198 amps
    221 amps
    The line speed is a little faster(except @ 2K lbs.) on the 24V version and it pulls less Amps.....
  9. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    It's better from the point that each 12V battery is only sourcing half the current(AMPS&gt;)
    And the motor should last longer.
    You might what to check with Warn for the date code, and if its less than half the new price
    it is worth it.
